Problem: One line code to execute if && else statements simultaneously
give me a one line code to execute if && else statements simultaneously.
dont use a ; after else statement !!!
pradeep_agrawal
😒 So your question is to write a C/C++ code in which the body of both if and else gets executed. Correct me if I am wrong.DEPgive me a one line code to execute if && else statements simultaneously.
dont use a ; after else statement !!! -
MayankHi DEP,
Can you please elaborate your question. Its not yet very much clear to me as to what exactly needs to be done? IF and ELSE executing simultaneously, can't get what does that mean !!! Please excuse me if I am asking a foolish question😁!!!!!!!!!
Thanks and Regards,
Mayank Shukla -
reachrkataIf I understood the question right, are you looking for the ?: operator - it does the same thing as an if and else but in 1 line.
Saket Mishrahey u can use the ? operator. It is called conditional operator.there are two conditional operators supported ? and :
for example
int x,y;
scanf("%d",&x);
y=(x>5?3:4); -
for example
int x,y;
scanf("%d",&x);
y=(x>5?3:4);
keep asking. -
DEP
firstly i apologise for not putting up my question clearly.pradeep_agrawal😒 So your question is to write a C/C++ code in which the body of both if and else gets executed. Correct me if I am wrong.
i rephrase my question.
"a c++ code whiich executes both 'if' and 'else' statements simultaneously.
if the code is
if(a==b)
cout<<"true\n";
else
cout<<"false";
OUTPUT should be:-
true
false
am i clear now??? -
DEP
hey saket,Saket Mishrahey u can use the ? operator. It is called conditional operator.there are two conditional operators supported ? and :
for example
int x,y;
scanf("%d",&x);
y=(x>5?3:4);
keep asking.
i know the conditional operator and i am sure that you know that its functionality is same as that of if/else. please read my question again in the new thread i have posted and my point will be clearer.
thanks -
maheshkrishnanHi,
There is way to make both "if " and "else" parts,like
if(a==b)
cout<<"true\n";
else;
cout<<"false";
execute this you will get both the If and ELSE part.
Thanks,
mahesh krishnan -
DEP
hi mahesh,maheshkrishnanHi,
if(a==b)
cout<<"true\n";
else;
cout<<"false";
Thanks,
mahesh krishnan
well the thing is that when i was asked this question..i gave the same answer.But then they said that the question is to executing both ie and else statements simultaneously and by terminating the "else" with a semicolon the following statement "false " is no more a part of "else". So the answer isnt acceptable.
please refer to the very first thread ,there i have explicitly mentioned not to use a semicolon after else. -
reachrkataI dont know about C++, but may be this works in C -
if (!(printf("TRUE"))
else
printf("FALSE");
Does the same also work in C++ using cout ?
maheshkrishnanHi DEP,
I hope it is just a Crazy question and should not comes in any part of programs.
Any way I will try one more time with a Old fassion of programming...
if (1)
loop😛rintf("TRUE\n");
goto loop2;
else
goto loop;
loop2: printf("FALSE\n");
Is this acceptable., Letz c.
Thanks,
Mahesh Krishnan -
DEPmaheshkrishnanHi DEP,
if (1)
goto loop2;
else
goto loop;
Thanks,
Mahesh Krishnan
hie mahesh,
GREAT job !!! congratulations..😁
keep up the good work,your answer is acceptable. -
DEPreachrkataI dont know about C++, but may be this works in C -
else
printf("FALSE");
hi reachrkata,
well your code is pretty cool and yes it works equally well in c++.
but there is a hitch. See the question eas to execute the statement following "if" and not the test condition of "if". i am not very much sure whether the code is acceptable but i will surely let you as early as possible.
but i must say GREAT WORK DONE.
regards,
DEP -
hajela_pushkar😎 use a ; after else. The statement's of both the if and else will be executed.
udgataGuys,
This can be done using the below code in C ...
if (!printf("True\n")😉
else
printf("False");
Let me know, if you have questions... -
suhit#include
#include
void main()
if(printf("Hello ")==-1)
else
printf("world");
getch();
Explanation:: As the library function printf()return the number of characters it prints and return 0 when nothing is printed, Hence in the if block whenever check occurs within the statement if(printf("Hello ")==-1),it becomes FALSE then after executing the printf("Hello ") part, the condition doesnt match as printf() does return the number of character, and it cant be negetive, so after print the "Hello " the control goes to the else block, Hence the printf("world"); part is executed, and the complete Hello World is printed on the screen, so both the blocks were executed.
Note: in the if condition checking, u can check the by any negetive number instead of -1(eg. -2,-3,-4,-5,-6,...). -
DEBASMITAif(condition)
printf("i");
else printf("am");
pl can ne1 tel me wat shud be d "condition" so dat "i am" will be printed?I hav compiled all d codes given bt none of them are successful -
Pensu@debasmita: i dont think you can print "i am" like this.....u might want to check solution provided by mahesh krishnan above.
suhit"DEBASMITA@Debosmita- if the control goes inside the if block, you will not be able to access the else block. If you really want to do this, you can use the go to statement that is already there in C. Like,
main()
if(1)
printf("Hello");
goto LINE_NUMBER;
else
printf("Hello");
here LINE_NUMBER is the line number of the printf statement in else block...
what is the involved for a robot to detect a line and detect it
[FONT=Verdana, sans-serif]Hello CEans![/FONT]
Lot of CEans are in their third/final year of Engineering. As students, they seldom get chance to face real life situations where they actually face the interviews....
I wish you could help me preparing for Gre with sample questions in Verbal.Im foxed .do not know where to start.
dear friends,
give me the link for strength of materials by timoshenko ebook.
regards
jp
Hi,
I am a student of CS-II year. I want to know that how and where i can do the summer training after completing my 2nd year?
