  • radha gogia
    @radha-BTDzli Sep 4, 2014
    anksinglabyte b=10 shows no error but
    float f =10.0 shows error that double found..
    why??
    see in java by default each decimal value is taken as double so u need to explicitly mention it be ,say 5.98f becoz it wont take it otherwise float,it would take it to be double,similarly byte b=18;here 18 is int by default but its value lies in the range of byte numbers that is we can represent 18 in byte so i hope now u are clear
  • anksingla
    @anksingla-ttYJbX Sep 4, 2014
    radha gogiasee in java by default each decimal value is taken as double so u need to explicitly mention it be ,say 5.98f becoz it wont take it otherwise float,it would take it to be double,similarly byte b=18;here 18 is int by default but its value lies in the range of byte numbers that is we can represent 18 in byte so i hope now u are clear
    But if 10 is int then it should not be matters that value comes in range of byte or not. Since java does not type demotion.
