  • Problem in getHostAddress() method in java
    Manish Goyal
    Manish Goyal
    @manish-r2Hoep
    Updated: Oct 22, 2024
    Views: 1.1K
    I am trying to create a simple program that will return the address of host ie my computer
    but it gives me exception null
    I don't understand why?
    here is my code
    import java.net.*;
    class Myserver
    InetAddress is=null;
    try
    String st=is.getHostName();
    System.out.println("Host address is "+st);
    catch(Exception e)
    System.out.println(e.getMessage());}
  • bharathpb
    MemberJun 7, 2010
    Not sure wats going wrong in ur code..
    InetAddress is=null; is setting the address to null...finally u get null.
    I tried a new code..try this one...
    import java.net.*;
    class Myserver1
    try
    { InetAddress addr = InetAddress.getLocalHost();
    System.out.println("Host address is " +addr);
    } catch (UnknownHostException e) {
  • Manish Goyal
    MemberJun 7, 2010
    Thanks for your response
    but still i am not getting same exception
    one thing is it possible to retrieve ip address that is allocated to me by my isp through this method ?
  • bharathpb
    MemberJun 7, 2010
    hi Goyal,
    from my above code..you will get both the system hostname and ip address allotted to u.
    Also post the exact exception so that i can debug...
  • Manish Goyal
    MemberJun 8, 2010
    nothing it just print null on console
    I don't understand what is the problem ?
    should i need to change my network settings?
    Do you use broadband?if yes then you program gives which ip address ?I mean that which was allocated by isp or any other?
  • sookie
    MemberJun 8, 2010
    Hi goyal420,
    I am using broadband connection and if I run bharathpb's program in my machine, it is working fine. It shows my machine's [hostname]/[ipaddress provided by ISP] in the output. I think you should once check network settings in your machine.
  • Manish Goyal
    MemberJun 8, 2010
    Thanks Guys for your reply
    now i am getting my ip address
    but why my program is not working ?I don't think that there is any syntax error but still there is a exception😕😕
  • bharathpb
    MemberJun 8, 2010
    goyal,,
    As already mentioned by me..provide the exact exception which you are getting...is it null pointer exception or is your output simply null????
  • Manish Goyal
    MemberJun 8, 2010
    yes it simply output null in case of my first program
