Problem in create Pdf using java
krishbcs
@krishbcs-5tG26c โ€ข Oct 27, 2024
hi
i need to create pdf for my data from orcle database using java. i am using following java coding
import java.io.*;
import java.sql.*;
import jpack.Database;
import com.itextpdf.text.Document;
import com.itextpdf.text.Paragraph;
import com.itextpdf.text.pdf.PdfWriter;
public class pdf
public static void main(String arg[])throws Exception
Database db=new Database();
Document document=new Document();
PdfWriter.getInstance(document,new FileOutputStream("d:/item.pdf"));
document.open();
PdfPTable table=new PdfPTable(2);
table.addCell("ITEMID");
table.addCell("ITEMNAME");
ResultSet rs=db.Select("Select * from item");
while(rs.next())
table.addCell(rs.getString("ITEMID"));
table.addCell(rs.getString("ITEMNAME"));
document.add(table);
document.close();
but it makes these of errors
--------------------Configuration: <Default>--------------------
C:\Documents and Settings\user\Desktop\Project\bala\DesignCodes\pdf.java:4: package com.itextpdf.text does not exist
C:\Documents and Settings\user\Desktop\Project\bala\DesignCodes\pdf.java:5: package com.itextpdf.text does not exist
C:\Documents and Settings\user\Desktop\Project\bala\DesignCodes\pdf.java:6: package com.itextpdf.text.pdf does not exist
C:\Documents and Settings\user\Desktop\Project\bala\DesignCodes\pdf.java:14: cannot find symbol
symbol : class Document
C:\Documents and Settings\user\Desktop\Project\bala\DesignCodes\pdf.java:15: cannot find symbol
symbol : variable PdfWriter
C:\Documents and Settings\user\Desktop\Project\bala\DesignCodes\pdf.java:17: cannot find symbol
symbol : class PdfPTable
8 errors
Process completed.
And also i download itextpdf-5.1.0 jar file. i don't know how i cleared this error.
please answer me.
  • rahul69
    @rahul69-97fAOs • Apr 3, 2013
    Looks like the library you are using (ie itextpdf ) is not accessible to your program.
    So add the library to the project classpath properly.
  • krishbcs
    @krishbcs-5tG26c • Apr 3, 2013
    please tell me how i add the library to the project class properly
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Apr 3, 2013
    krishbcsplease tell me how i add the library to the project class properly
    java -help (hint: start exploring options)
  • rahul69
    Check out this link: #-Link-Snipped-#
  • cathyhill
    @cathyhill-nOHQdu • Feb 13, 2014
    krishbcshi
    i need to<a href="https://www.rasteredge.com/how-to/vb-net-imaging/pdf-get-to-start/" target="_blank" rel="nofollow noopener noreferrer">VB.NET PDF: Get Started with PDF Library</a> for my data from orcle database using java. i am using following java coding
    I think you have to mark sure that you have get the permission to use the library.
  • moksh
    @moksh-Nnq2IU • Feb 19, 2014
    I have been using a 3rd party API from Jasper soft called Ireports ...it has extensive support for java ...code and tutorials are extensively available .... so far its the beswt opensource tool for pdf HTML and CSV reports..
    Enjoy
