  • problem in a c program
    accoolaryan
    accoolaryan
    @accoolaryan-BYyoWn
    Updated: Oct 26, 2024
    Views: 1.9K
    hi
    i want to include a dos command in c program .
    how can i include it so when i run my program so it should run that command?
  • dipen30
    MemberFeb 1, 2010
    there is a header file in c "dos.h" include that file.
  • gaurav.bhorkar
    MemberFeb 1, 2010
    accoolaryan
    hi
    If you are using Visual C++ or Dev C++ to compile your programs, then you can use the system () function. Make sure you #include <stdlib.h> in your program.
    Syntax:
    system ("command");
    For eg. to clear the screen you can use - system ("cls");
  • Manish Goyal
    MemberFeb 1, 2010
    addition to previous post
    Don't forget to use
    #include<stdlib.h>
