  • Pressure Measurement
    Updated: Oct 26, 2024
    [FONT=&quot]Pressure Measurement[/FONT]
    -A major concern in process control applications is the measurement of fluid pressure. The term fluid means a substance that can flow; hence, the term applies to both liquids and gases. Both will occupy the container in which they are placed.
    -The pressure is equal to the force applied to the walls divided by the area that is perpendicular to the force. For a liquid at rest, the pressure exerted by the fluid at any point is perpendicular to the boundary of the liquid. Pressure is defined as a force applied to, or distributed over, a surface area as:-
    P=F/A
    Gauge and Absolute Pressure
    -Absolute pressure is the pressure measured above total vacuum or zero absolute, where zero absolute represents a total lack of pressure.
    -Gauge pressure is the pressure measured above atmospheric or barometric pressure. It represents the positive difference between measured pressure and existing atmospheric pressure.
    #-Link-Snipped-#​
    Pressure Gauges
    -Pressure gauges are used for local indication and are the most common type of pressure-measurement instrument used in process industries. Pressure gauges consist of a dial or indicator and a pressure element. A pressure element converts pressure into a mechanical motion.
    -Most mechanical pressure elements rely on the pressure that acts on a surface area inside the element to produce a force that causes a mechanical deflection. The common elements used are Bourdon tubes diaphragms and bellows elements.
    -The following figure shows one of the most common and least expensive pressure gauges used in the process industries. This pressure gauge uses a “C” type Bourdon tube. In this device, a section of tubing that is closed at one end is partially flattened and coiled. When a pressure is applied to the open end, the tube uncoils. This movement provides a displacement that is proportional to the applied pressure. The tube is mechanically linked to a pointer on a pressure dial to give a calibrated reading.
    #-Link-Snipped-#​
    - A Diaphragm is another device that is commonly used to convert pressure into a physical movement. A diaphragm is a flexible membrane. When two are fastened together they form a container called a capsule. In pressure- measuring instruments, the diaphragms are normally metallic. Pressure applied inside the diaphragm capsule causes it to expand and produce motion along its axis.
    - A diaphragm acts like a spring and will extend or contract until a force is developed that balances the pressure difference force. The amount of movement depends on how much spring there is in the type of metal used.
    - To amplify the motion that a diaphragm capsule produces, several capsules are connected end to end, as shown in the following figure. You can use diaphragm- type pressure gauges to measure gauge, absolute, or differential pressure.
    #-Link-Snipped-#​
    - The Bellows pressure element is very similar to a diaphragm-type gauge in that it converts a pressure into a physical displacement. The difference is that typically the movement in a bellows is much more of a straight-line expansion. A typical bellows-type pressure gauge is manufactured by forming many accordion-like pleats into a cylindrical tube
    -You can use the motion that the pressure input signal produces to position a pointer, recorder pen, or the wiper of a potentiometer.
    #-Link-Snipped-#​
  • shubhankar
    MemberApr 9, 2011
    really valuable information. McLeod's guage can also be used reliably above 0.0001 torr (0.01 pascal). pirani guage , ionisation guage are also useful in pressure measurement.
  • ISHAN TOPRE
    MemberApr 9, 2011
    Good information Khaled Bhai. Simple. It will also serve those who often get confused with these guages or those who are beginning to learn. Keep up the good work. 😀
