php - jquery - ajax help on wordpress - what's wrong with my code?
WPLearner
WPLearner
@wplearner-n04o1W Oct 26, 2024
Hey all! I'm new to this site and I think I can get help with the code I'm trying to write. I am new to wordpress, php and ajax and writing this simple addon that adds two numbers and shows the result below. I know it's useless; but it will help me learn
// PREPARATIONS - Enqueue All Javascript
function ajax_enqueue_scripts($hook) {
    wp_enqueue_script('adder', plugins_url('/js/adder.js', __FILE__), array('jquery'), '1.0', true);
add_action('admin_enqueue_scripts', 'ajax_enqueue_scripts');
// STEP I : Create admin menu
function adder_admin_menu() {
    add_menu_page('ADDER', 'ADDER', 'manage_options', 'adder', 'display_adder_form', 'dashicons-plus', 81);
add_action('admin_menu', 'adder_admin_menu');
// STEP II : Display adder form on the menu page created above
function display_adder_form() {
    //END PHP TAG TO WRITE SOME HTML?>
        <!-- HTML FORM TO DISPLAY ADDER BEGINS -->
        <div class="wrap">
            <h1>The Ultimate Adder</h1>
            <form id="adder_form" class="adder_form" name="adder_form" method="POST" action="/wp-admin/admin-ajax.php?action=ultimate_adder">
                <input type="text" name="number1" id="number1" placeholder="#1" />
                <input type="text" name="number2" id="number2" placeholder="#2" />
                <input type="submit" class="button-primary" value="Calculate & Save To DB" >
            </form>
        </div>
        <div class="answer">
            <!--inner html is replaced by ajax -->
        </div>
    <?php //PHP TAG REOPENED
function
ultimate_adder() {
$number1 $_POST["number1"];
$number2 $_POST["number2"];
$result $number1 $number2;
$result = (array)$result;
    return
json_encode($result);
And the corresponding JavaScript (adder.js) -
jQuery(document).ready(function($){
    var wpajaxurl = '/wp-admin/admin-ajax.php?action=ultimate_adder';
    $('form.adder_form').bind('submit', function(){
            $form = $(this);
            var form_data = $form.serialize();
            $.ajax({
                'method' : 'post',
                'url' : wpajaxurl,
                'data' : form_data,
                'dataType' : 'json',
                'cache' : false,
                'success' : function (data, textStatus) {
                    $(".answer").html("Answer:" + data["result"]);
                'error' : function (jqXHR, textStatus, errorThrown) {
                    alert("FAIL");
        return false;
My code works to a point that I get 'undefined' as my response below my form. Can someone point out what part of it is going bong? Thanks in advance for your time.
    @thebigk Feb 6, 2016
    I'm no expert in coding; but you may try the following -
    return
    Replace it with
     $result = array('Answer' => $result);
    die(
    $result);
    I think you'll have to die towards the end of your function.
    Also check if your JS is being called properly on your admin page. That should do the trick. Let us know if it works.
