  • PDF to EXCEL convertion through Java
    imgopi
    imgopi
    @imgopi-dUGWP0
    Updated: Oct 26, 2024
    Views: 1.7K
    Hi friends i want to do my main project on java.The main aim is to store university result in database,the university send a PDF file to respected colleges.So my activities are
    1)converting PDF to excel
    2)and storing that file in database
    so help me and give me your suggestions for this task,
    and what are the classes needed for conversion of files through Java.
  • ms_cs
    MemberJan 5, 2012
    Apache PDFBox is an java API, you can use this to extract the pdf data
  • PraveenKumar Purushothaman
    MemberJan 5, 2012
    Try this out:
    import java.io.FileOutputStream;
    import com.lowagie.text.Document;
    import com.lowagie.text.Rectangle;
    import com.lowagie.text.pdf.BaseFont;
    import com.lowagie.text.pdf.PdfContentByte;
    import com.lowagie.text.pdf.PdfImportedPage;
    import com.lowagie.text.pdf.PdfReader;
    import com.lowagie.text.pdf.PdfWriter;
    public class ReadYourOwnPDFFile {
        public static void main(String[] args) {
            try {
                PdfReader reader = new PdfReader("YourOwnPDF.pdf");
                int n = reader.getNumberOfPages();
                // we retrieve the size of the first page
                Rectangle psize = reader.getPageSize(1);
                System.out.println(reader.getPdfVersion());
                System.out.println(reader.getFileLength());
                System.out.println(psize.height());
                System.out.println(psize.width());
            catch (Exception de) {
                de.printStackTrace();
  • imgopi
    MemberJan 5, 2012
    Thanks...
  • imgopi
    MemberJan 5, 2012
    Praveen-Kumar
    Try this out:
            try {
    First thanks for your response and this program gives information about the PDF file friend,but i need Excel file from PDF.
    MemberJan 5, 2012
    imgopi
    Okay... Lemme try out something and get back to you... 😀
  • simplycoder
    MemberJan 6, 2012
    imgopi
    If its fine with you, kindly upload the sample file along with the code that you have tried.
  • imgopi
    MemberJan 6, 2012
    simplycoder
  • Sandhya Nattu
    MemberJun 29, 2012
    hi gopii ,
    did you got the source code of how to convert the pdf file to excel using java . i m also working with it will u please help me by giving code or in tracing how to convert???
  • imgopi
    MemberJul 16, 2012
    Sandhya Nattu
    hi gopii ,
    Sorry for late reply
    First I convert PDF to Word then I convert it to Excel
  • Sandhya Nattu
    MemberJul 16, 2012
    Will you provide me code 😀 plz
  • pittypan
    MemberFeb 20, 2014
    Sandhya Nattu
    hi gopii ,
    did you got the source code of how to <a href="https://www.rasteredge.com/how-to/vb-net-imaging/pdf-render-option/" target="_blank" rel="nofollow noopener noreferrer">VB.NET PDF: Set PDF Document Rendering Options in VB.NET Class</a> file to excel using java . i m also working with it will u please help me by giving code or in tracing how to convert???
    Google is a good friend. Try this link where you can find the sample code.
    <a href="https://www.codeproject.com/Answers/394089/PDF-table-data-to-Excel-using-Vb-net.aspx#answer1" target="_blank" rel="nofollow noopener noreferrer">[Solved] PDF table data to Excel using Vb.net - CodeProject</a>
  • Ainur
    MemberMar 28, 2014
    Hello.
    You solved the problem. Can you help me?
    imgopi
  • cathyhill
    MemberApr 7, 2014
    pittypan
    <a href="https://www.codeproject.com/Answers/394089/PDF-table-data-to-Excel-using-Vb-net.aspx#answer1" target="_blank" rel="nofollow noopener noreferrer">[Solved] PDF table data to Excel using Vb.net - CodeProject</a><a href="https://www.rasteredge.com/how-to/vb-net-imaging/excel-converting/" target="_blank" rel="nofollow noopener noreferrer">VB.NET Excel: Convert & Render Excel Sheet to Other Documents & Images</a>
    Thanks, pitty, it helps.
  • Dinesh Chandewar
    MemberMar 27, 2017
    hi friends i want to convert pdf file into excel sheet in java programming .....so any one help me..............
