Numericals on Transistors - Questions & Answers [Solved]
Numerical on current , amplification factors of transistors
Some basics:
1. Generalized expression for collector current:
IC = α IE +IC0[1-e(Vc/VT)]
Where VC is the negative and is very large as compared to VT . the physical interpretation is that the P-N junction diode current crossing the collector junction is supplemented by the fraction α of the current IE .
2, Current amplification factor:
a. The alpha factor is the current amplification factor and is the ratioof the collector current to the emitter current
α =Δ IC/ΔIE , where VCB should be constant,
This value of alpha is always less than 1
b. The beta factor β is the current gain factor (transport factor) of the common emitter circuit and is defined as the ratio of collector current to the base current.
β =Δ IC/ΔIB
c. Relationship between α and β
α = β/1+ β and β= α/1- α
Numerical
1. In a certain transistor , collector current is 0.98 mA and base current is 20mA. Determine the value of 1. Emitter current, 2. Current amplification factor 3. Current gain factor
Solution: for emitter current , please draw the circuit of common base configuration , gives weigtage, the as per Kirchhoff’s law find emitter current.
Other two factor can be found out by direct formulas
2. Determine the values of emitter current and collector current of the transistor having α=0.98 and collector to base leakage current ICB0 = 4µA . the base current is 50 µA.
Solution: collector current is given as: IC= αIE+ICB0 and IE=IC+IB .
Thus using this two answer can be found out.
3. The BJT has IB = 10 µA, β= 99 and IC0 = 1 µA. what is collector current IC ?
Solution: IC= αIE+ICB0 and β= α/1- α will provide you with the answer.
Some basics:
β =Δ IC/ΔIB
Numerical
Sushmita Behera
It is nice.. Easy to understand for beginners
Pratik Bhaumik
Purely nonsence
Pratik Bhaumik
The most nonsense site ever made
Hotelogix, a cloud based property management and distribution system, was founded by Prabhash Bhatnagar and Aditya Sanghi in 2008. With its headquarters in New Delhi NCR, India, Hotelogix raised $1.2...
Adidas has launched its newest accessory - a smartwatch named "miCoach SMART RUN" in India at a price of Rs. 24,999. The smartwatch tracks and monitors your performance data and...
ISlamist group of Iraq and Syria(ISIS), the child of Al Qaeda is creating terror in the hearts of not just the Iraq and Syria but also in the neighbouring countries...
European Union, an economic body formed as a consortium of 28 european nations with a unified currency euro should bring welfare, development. But unfortunately it has been failed to control...
I have idea to safe vehicle and life.
Safety Bumper:- it can be used for all vehicles to prevent damage to vehicle in case of accident.
Two shock absorber and...
