N-Solv’s Oil Extraction Process For Canadian Oil Sands Is 85% Greener
Canada has many huge oil deposits that are yet unexplored. The oil reserves are considered to be large enough to satisfy the demands of the United States for at least a few decades. Then why do the US and the whole of Europe depend on the Middle Eastern oil reserves? The answer is very simple. The Canadian oil deposits are in the form of oil sands and are made up of a thick, tar like substance called Bitumen. It is not an easy job to extract oil from these sands. The process requires great energy and sophisticated machinery to take out the crude oil and the transportation up to the refinery is one more headache. The fossil fuel burnt in the transportation, extraction, and refining stages is considerably higher and ecologists all around the globe claim that such extraction can lead to drastic climate changes. The plans for constructing a pipeline from Canada to USA to transport the crude oil to the refineries are also under the public scanner.
N-Solv's research statistics
However, a Canadian conglomerate N-Solv has come up with a brilliant solution for this problem and devised a new oil extraction technology. This technology, they claim is efficient, economical and also eco friendly. It is expected to bring down the greenhouse gas emissions by a whopping 85% compared to the previously used methods. N-Solv received Canadian governmentâs backing and a huge fund of $10 million for this project. N-Solv is having its headquarters in Alberta. It says that the new technology will allow faster and pollution free oil extraction and will double up the amount of oil that can be extracted from each reserve.
The conventional oil extraction approach requires excavating the shallow, sandy oil filled deposits. After that the sludge like viscous bitumen is processed to extract the crude oil with the help of heat and chemicals. Then the oil is made less viscous so that it can be transported to the refinery via a pipeline. This approach doesnât work for the deep seated oil sand deposits. And, 80% of the oil deposits lie below this depth! To extract from these deeper levels, the bitumen must be treated while itâs still underground and forced out afterwards through an oil well. For this, generally steam is forced down to make the bitumen melt and come out. Still the oil is not fluid enough to flow through the pipeline and needs a bit of refining. These processes, producing steam and refining the oil require huge amounts of fossil fuels to be burnt. This leads to green house gas emissions.
The method adopted by N-Solv for this new technology is pretty simple and effective. The steam is replaced by a liquid solvent such as propane. The propane is heated to a much lower temperature (about 50º) and forced underground. The result is dissolved bitumen and the oil taken out is much more fluid so no refining is required at this point. The propane that comes up can be easily reused. Also, the energy wasted in heating the water, refining the oil, etc. is saved. Thus, the process is much efficient and less polluting due to lesser burning of fuels. Since the energy requirement is less, the process is cheaper. The machinery required for heating, purifying and reusing propane is very cheap compared to that required for the management of large volumes of water used in the steam process. The earlier technology had led to the oil prices become inflated and reach above $50 to $60 per barrelâas they have been for several years. But the lowered cost of extraction makes it economical even at $30 to $40 per barrel. Till now this has been tried only in laboratory experiments. But, with the initial success the N-Solv is planning to start a pilot project with a starting investment of $ 60 million made by a few private firms. The project will aim to have a daily target of 500 barrels. If this experiment succeeds, then its viability on a larger scale will be proven.
Image: #-Link-Snipped-#
The Arabs love to break records and when it comes to constructing tallest towers in the world, money is no bar for them. We informed you few days ago that ...
Harvard's School of Engineering and Applied Sciences (SEAS) have come up with a chip that can detect unknown liquids within seconds. The technology used to develop the chip is called...
Lexus has recently announced that its latest GS 350 mid size sport sedan will be revealed two weeks later on August 18 in conjunction with Pebble Beach Concours d’Elegance. The...
Engineers at the California Institute Of Technology (Caltech) have engineered the next generation of computer chip technology called 'Photonic Chips'. The photonic chips allow integrated circuits to use light instead...
In a latest technological breakthrough, a modern glove device that gives vibrational feedback to the fingertips on physical interaction with surfaces has been formulated to develop wearers’ sensitivity of touch....
