  • Java mail sending probelm?
    krishbcs
    krishbcs
    @krishbcs-5tG26c
    Updated: Oct 25, 2024
    Views: 1.0K
    I try to make a java coding to send mail. java code as follow
    * To change this template, choose Tools | Templates
    * and open the template in the editor.
    package sendemail;
    import java.util.*;
    import javax.mail.*;
    import javax.mail.internet.*;
    import javax.activation.*;
    import java.security.Security;
    import javax.mail.Message.RecipientType;
    * @author mohamed
    public class SendEmail {
    public static void main(String[] args) {
    String from = "#-Link-Snipped-#";
    String to = "#-Link-Snipped-#";
    String subject = "Test Message";
    String message = "This is A test message sent via Gmail ";
    SendMail sendMail = new SendMail(from, to, subject, message);
    sendMail.send();
    class SendMail {
    private String from;
    private String to;
    private String subject;
    private String text;
    public SendMail(String from, String to, String subject, String text)
    {this.from = from;
    this.to = to;
    this.subject = subject;
    this.text = text;}
    public void send(){
    String host = "smtp.gmail.com";
    String userid = "#-Link-Snipped-#";
    String password = "mypassword";
    try
    Properties props = System.getProperties();
    props.put("mail.smtp.starttls.enable", "true");
    props.put("mail.smtp.host", host);
    props.setProperty("mail.transport.protocol", "smtps");
    props.put("mail.smtp.user", userid);
    props.put("mail.smtp.password", password);
    props.put("mail.smtp.port", "465");
    props.put("mail.smtps.auth", "true");
    Session session = Session.getInstance(props, null);
    MimeMessage message = new MimeMessage(session);
    InternetAddress fromAddress = null;
    InternetAddress toAddress = null;
    try {
    fromAddress = new InternetAddress(from);
    toAddress = new InternetAddress(to);
    } catch (AddressException e) {
    e.printStackTrace();
    message.setFrom(fromAddress);
    message.setRecipient(RecipientType.TO, toAddress);
    message.setSubject(subject);
    message.setText(text);
    //SMTPSSLTransport transport =(SMTPSSLTransport)session.getTransport("smtps");
    Transport transport = session.getTransport("smtps");
    transport.connect(host, userid, password);
    transport.sendMessage(message, message.getAllRecipients());
    transport.close();
    } catch (MessagingException e) {
    but it creates exception error, and i also find out solution for this error in google, nobody can properly clear this error. error as follows:
    --------------------Configuration: <Default>--------------------
    javax.mail.MessagingException: Could not connect to SMTP host: smtp.gmail.com, port: 465;
    nested exception is:
    javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1706)
    at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:525)
    at javax.mail.Service.connect(Service.java:291)
    at javax.mail.Service.connect(Service.java:172)
    at sendemail.SendMail.send(SendEmail.java:82)
    at sendemail.SendEmail.main(SendEmail.java:29)
    Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
    at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1540)
    at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:203)
    at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:197)
    at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:994)
    at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:142)
    at sun.security.ssl.Handshaker.processLoop(Handshaker.java:532)
    at sun.security.ssl.Handshaker.process_record(Handshaker.java:470)
    at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:837)
    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1049)
    at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1076)
    at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1060)
    at com.sun.mail.util.SocketFetcher.configureSSLSocket(SocketFetcher.java:503)
    at com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:234)
    at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1672)
    ... 5 more
    Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:302)
    at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:205)
    at sun.security.validator.Validator.validate(Validator.java:235)
    at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:147)
    at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:230)
    at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:270)
    at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:973)
    ... 15 more
    Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:191)
    at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:255)
    at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:297)
    ... 21 more
    Process completed.
  • krishbcs
    MemberApr 23, 2013
    this program work perfectly before 2 weeks. but at the same program creates exception error.
  • rahul69
    MemberApr 23, 2013
    krishbcs
    Shouldn't you be using port no 25 (or 587) instead of port 465?? (I maybe wrong though..)
  • krishbcs
    MemberApr 24, 2013
    it's also same error.
