Intrinsic and Extrinsic semiconductors
Intrinsic and Extrinsic Semiconductors
Intrinsic Semiconductors:
1. Semiconductors material in extremely pure form is called intrinsic semiconductor.
2. Free electrons and holes are generated in pairs. Thus concentration of holes is equal to that of electrons.
3. At absolute zero temperature (-273°C), the intrinsic semiconductor, all the electrons are tightly held by their atoms. With increase in temperature the electrons break in through the atoms, and move from valence band to conduction.
4. Temperature increase à electrons - holes pair generation increase àconductivity of intrinsic conductor increase à resistivity decrease.
5. Thus semiconductors have negative temperature coefficient.
Extrinsic Semiconductors:
1. Addition of impurity to pure semiconductor results into extrinsic semiconductor. It is known as doping.
2. The material that is added to it is called doped material. Germanium or silicon is tetravalent. (4 electrons in the outermost orbit). So either a pentavalent or trivalent impurity can be added to it.
3. It has high conductivity as compared to that of intrinsic semiconductor even at room temperature .
4. According to the added impurity they are classified as:
a. Donor type or N-type
b. Accepter type or P-type
A. N-type Extrinsic Semiconductors:
1. Pentavalent impurity is added.
2. Arsenic, phosphorus
3. So one electrons is left enters into the conduction band as a free electron. So negative charge. Thus N-type
4. Number of holes is small as compared to the number of electrons.
B. P-type Extrinsic Semiconductors:
1. Trivalent impurity
2. Boron, alluminium etc
3. So three electrons get combined and one hole is left. Thus positive charge. Therefore P-type.
4. Number of electrons is small as compared to number of electrons.
Q. There are many semiconducting materials, they why mostly Si and Ge is used?
-> because the energy require to break the covalent bonds of Ge and Si is small as compared to other semiconductors. i.e Ge=0.72 eV and Si=1.12 ev.
-> they have same crystal structure.
ambrish gautamThere may be some reason to do so,
si is easy to get, and able in earth. we can get sio2 easily from si. si has min leakage current, we can use si in high temperature.
due to above we use si.
but parrallely there is one disadvantages of using si that is si has less conductivity so we go for Ge.
but now a day we using GeAs as semiconductor material, but it's very expensive and has the property of negative differential mobility. and this complex material loss energy in the form of light so GeAs usually use in led.
Inp is being in use for led diode purpose. -
Abhishek Yadav
Can semiconductor have +ve temperature coefficient?
NASA is planning to use Google's 3D mapping technology for its SPHERES project. SPHERES which stands for Synchronized Position Hold, Engage, Reorient, Experimental Satellites was deployed by NASA in 2006...
I am not able to access google drive since many days, is it working for you or it's just me?
I confess that I am shocked at the results of this off beat study in Virginia. Maybe Indians are more used to meditation and the results in India could be...
Hi CEans !! it has been a long time seeing yu guys !!hope you all are gud 😀
Fortunately I currently joined as an intern in an R&D organization.i was...
*Name: Nikhil (ya datsan's a nick 😛)
*Engineering Trade: Electrical and Electronics
*Occupation: Unemployed
*Work Experience: none
*Hobbies & Interests: none worth mentioning
*Aim in life: survive
*I joined CrazyEngineers...
