hydrogen-cooled generator
IF007
@if007-4L3LLt โ€ข Oct 25, 2024
Hi,
Can someone help me in this matter:
I would like to know if it is possible to use air instead of hydrogen in a hydrogen-cooled generator. If it is possible, what would be the conditions to do it. If not please justify your answer (e.g. safety reasons, efficiency, what can go wrong, etc.)
Thanks
  • Jishnu Gupta
    @jishnu-gupta-UNpHpS Feb 5, 2011
    Heyy dude..look broda.....
    lemme 1st tll ya d reasnz y we use H2 intead of normal air
    Firstly lemme start with an example you have seen bike engines say upto 300cc dey all are air cooled ryt now take a look at a basic car engine say maruti 800 is it air cooled to......???????? no we use a coolent ryt....y d reason is the generated heat. Heat is d most important factor in deciding the coolent material so as far as a generator is concerned u can uslf imagine d amount of heat generated........
    Nw here r d reasons y we use hydrogen
    V.imp is its low density secondly high specific heat then highest thermal conductivity at 0.168 W/(mยทK) of all gases; it is 7-10 times better coolant than air(wich i think your question for replacement of hydrogen)
    Another very important feature is that its easy detection by hydrogen sensors.
    A hydrogen-cooled generator can be significantly smaller, and therefore less expensive, than an air-cooled one.
    Hope ma answer satisfies your question frnd.....๐Ÿ˜€
    @thebigk Feb 5, 2011
    @Jishnu: Please do not use SMS language on CE Forums.
  • narayana murthy
    @narayana-z4W16q Feb 5, 2011
    Jishnu is right i support his answer
  • baja
    @baja-LumPX0 Feb 8, 2011
    Jishnu is absolutely right. But I want to add one more point. Cooling in an machine is nothing but to reduce Hot Spot Temperature(HST) of the windings. Only HST limits the capacity of a machine. If u use air then the heat carried away by the air is less than that of hydrogen. So hot spot ll be attained for lower loads hence decreasing machine capacity.
  • DanielEMccarty
    @danielemccarty-i9F0LJ Feb 9, 2011
    I was extremely happy to locate this webwebsite.I wanted to thank you with regard to this terrific read!! I certainly appreciated every little bit of it and I've you bookmarked to look at new things you publish.
  • dheerajkvs
    @dheerajkvs-ycESs6 Feb 10, 2011
    Thanks for the question IF007 i have learnt something new with your help
  • Ron Prakhar
    @ron-prakhar-DbXbZx Feb 12, 2011
    i am also satisfy with this answer.
