How to start 8051 programming?
RAJ KUMAR JANGRE
@raj-kumar-jangre-0Slrad โ€ข Oct 26, 2024
hello CEs,
I want to do simple programming on 8051 processor, can anyone suggest me what are the instrument i need to purchase and how to start programming.
    @abhishek-fg9tRh • Aug 25, 2014
    RAJ KUMAR JANGREhello CEs,
    For simple programming, no need to waste money in hardware. Simple download emulator/IDE (#-Link-Snipped-# or Keil), pick up #-Link-Snipped-# & begin coding.
    @abrakadabra • Aug 25, 2014
    Abhishek is right. Emulators is the best way to start.
    And Mazidi seems to be the top-favorite for beginners. ๐Ÿ‘
    If you are really starting out from absolute scratch, this PDF should help you -
  • RAJ KUMAR JANGRE
    @raj-kumar-jangre-0Slrad • Aug 25, 2014
    thanks for replies.
    I will read it first. If I found any difficulties then i will come back to you,
    @harshad-ukH5ww • Aug 25, 2014
    #-Link-Snipped-# as #-Link-Snipped-# said start with emulator and you will get idea about how to write basic code. And I think you can also ask in college if they have some hardware kits based on 8051 then you can learn how to write program in KEIL and then start hands-on actual hardware.
  • a.alandkar
    @aalandkar-R9Nf1k • Aug 26, 2014
    Hello Mate,
    First of all I would like to correct you, 8051 is not a processor its a controller. Already you have got good and helpful replies, one more option i would like to suggest n i.e. you can use Keil for compilation of the code and Proteus for simulation of the code. Once you get hands on 8051 coding then you can upgrade yourself to actual hardware.
  • jeshukb09
    @jeshukb09-d2BfWu • Aug 31, 2014
    Hi Rajkumar
    Already you have got many of the suggestions and solutions.
    I just want to give some points about them. Mazidi is good text to refer for learning the coding of 8051 Micro-controller.
    If you are using MCU 8051 IDE then you have to program with HEX code itself. And while using JUMP instructions you will have to calculate the distance of the memory to be jumped and the code that you are using for the purpose and its scope. So, if you are some what good in C programming yhen it is preferable to KEil as it will generate the HEX code from the C program you have written. Also you will be having the option to burn the program to the so called micro-controller.
  • Ramesh_Kumar
    @ramesh-kumar-JzVhsI • Oct 29, 2014
    Good suggestions above, my advice for the beginners is Keil compiler is user friendly and efficient. after you do practice codes on keil compiler and cheking output on any simulator like Proteus, if you wish to go for hardware to check your codes and do new experiments, go for Atmel 89c51 its a simple 8051uC. But you need additional programmer to dump hex file into the controller a costly affair.. There is another controller from Philips(NXP Semi) P89v51rd2 which was also easy to do simple coding experiments which do not need external programmmers. you can directly dump the Hex file using its onchip Programmable capability with RS-232 serial interface by this you can prepare your own practicing kit in a very low cost. I am attaching the kit schematic i have designed and all the components are referenced with values. all are very basic components and its very easy and excited task to build your own basic programming kit your own in a very minimal cost. using a RS-232 serial cable you can simply plug your board to our PC and directly dump programs with no risks and no time waste.
    <a href="https://www.keil.com/dd/chip/3711.htm" target="_blank" rel="nofollow noopener noreferrer">NXP (founded by Philips) P89V51RD2</a> -link for more details about the chip. If anybody interested in Basic learnings of Microcontroller hardware and coding, i will post some more tutorials according to my knowledge and experiance.
    Thank you...
