    @thebigk Mar 22, 2013
    First make sure tomcat is installed, if not get the addon from: #-Link-Snipped-#
    If required, configure tomcat port number to avoid conflict (should not be required, but better check) -
    Look for the following on tomcat install directory -
    C:\xampp\tomcat\conf\server.xml
    <Connector port="9000" protocol="org.apache.coyote.http11.Http11AprProtocol"
    connectionTimeout="20000"
    redirectPort="8443" />
    Check User Name and Password for Tomcat
    C:\xampp\tomcat\conf\tomcat-users.xml
    <tomcat-users>
    <role rolename="manager"/>
    <role rolename="admin"/>
    <user username="xampp" password="xampp" roles="admin,manager"/>
    </tomcat-users>
    Hope this helps.
  • Ashish Ahuja
    Ashish Ahuja
    @ashish-BWkEaJ Mar 23, 2013
    Well thanks sir for the reply but the tomcat is already a part of the basic package with this version of xampp. And as per the codes mentioned above , these are as on my machine :
    <Connector port="8080" protocol="HTTP/1.1"
    <tomcat-users>
      <role rolename="tomcat"/>
      <role rolename="role1"/>
      <user username="tomcat" password="tomcat" roles="tomcat"/>
      <user username="both" password="tomcat" roles="tomcat,role1"/>
      <user username="role1" password="tomcat" roles="role1"/>
    </tomcat-users>
    Should i change these to the ones mentioned by you? and after I do it, what should i do next to get a jsp page running on my browser window?
    @thebigk Mar 23, 2013
    It'd be difficult to respond without knowing what the error is. Are you getting a blank page or some error?
    @abrakadabra Mar 18, 2014
    In case, if someone is still looking into this and facing an issue, I hope these step by step process can be of help -
    1. Download Apache Tomcat addon #-Link-Snipped-#.
    2. Extract tomcat addon in Xampp server root directory
    3. Go to C://xampp/
    4. Stop all services of xampp
    5. Open shell and relocate all services
    6. Enable mod_jk and relocate
    7. Start the services
    8. In Xampp control panel you will see the tomcat service. Activate it.
    9. Click on admin and enter username and password as xampp and xampp
    10. There you go! Open tomcat admin!
  • keshav_1994
    keshav_1994
    @keshav-1994-dtcdU6 Jul 18, 2014
    I m new in making servlet and jsps...
    previously i was using tomcat on eclipse now i want to shift it to xampp....
    i have changeg the port of tomcat at eclipse nd my tomcat server has been started successfully although i didnt get the 5th point told by miss.ankita to relocate services....
    but the problem is i am abe to get :-
    1) where to save jsp file (i saved in ht docs nd i did run it using localhost/calc.jsp)
    but it is showing me the code on browser rather dan the result of application... and the same application works fine on eclipse...
    wat to do?
  • Ashish Ahuja
    Ashish Ahuja
    @ashish-BWkEaJ Jul 19, 2014
    In order to run jsp with XAMPP you need to place your .jsp files in the webapps directory of your tomcat folder within your xampp installation folder.
    {xampp_installation_folder}/tomcat/webapps
    and use the #-Link-Snipped-#
    to run your .jsp file.
  • crusadersplanet
    crusadersplanet
    @crusadersplanet-mWGxe9 Jul 21, 2014
    remove comments
    remove <!-- and -->
  • janardan kumhar
    janardan kumhar
    @janardan-kumhar-jEQcgj Aug 30, 2015
    No need to change username and password ..
    1.) Remove comments <!-- and --> from <tomcat-users>
    2.) Start Tomcat
    3.) Copy your page or project to xampp/tomcat/webapps/project-1
    4.) go to browser .. type .. locahost:8080/project-1
