How to interpret NETSTAT command?
durga ch
@durga-TpX3gO โ€ข Oct 26, 2024
How do we actually interpret netstat command.
For eg:consider the below result for a port 'abc' on the server xxx.
netstat -a | grep abc
tcp 0 0 xxx.abc yyy.1 ESTABLISHED
tcp 0 0 xxx.abc yyy.2 ESTABLISHED
tcp 0 0 *.abc *.* LISTEN
tcp 0 0 xxx.abc yyy.3 CLOSE_WAIT
Ah! I understand its a tcp connection and abc are listening ports trying to listen to the 'established' connection from the ports 1,2,3 from a client machine yyy.
Outgoing packets and incoming packets are 0 currently and since a TCP connection from yyy.3 can be 'closed' to abc port of xxx only after yyy receives a ack from xxx.
I feel I am missing upon other stuff here, any other deductions?
  • Anil Jain
    @CrazyBoy Oct 5, 2009
    Ah !! nice topic, I always loved to discuss about commands.
    netstat (network statistics) is a command-line tool that displays network connections (both incoming and outgoing), routing tables, and a number of network interface statistics. It is available on Unix, Unix-like, and Windows NT-based operating systems.
    It will take lots of space to explain the command with each attribute. For in depth knowledge of NETSTAT you can refer the following sites:
    For Windows: #-Link-Snipped-# (Netstat command)
    For Linux: #-Link-Snipped-#
  • madhumurundi
    @madhumurundi-DfePI4 Oct 12, 2009
    to know about more on netstat type netstat -? in command prompt you will get an help mesage
