  • Rohan_sK
    @rohan-sk-7ZbDkK • Nov 12, 2009
    This is a very generalised question and can have a detailed answer with many points to mention. But here are a few basic ones.
    1. Have the proper ratio of the A/F mixture, neither too lean nor too rich. Keep it close to the Stoichiometric ratio. Richer mixtures increase the CO2 and NO2 emissions.
    By the way these days there are Direct Injection methods and also the mixture ratio is controlled according to the speeds dynamically by chip driven systems thus improving efficiency even more.
    2. Maintain the Higher Compression Ratio but not too high to cause a knock or what is called a Detonation. Keep the proper balance, for Diesels its around 24:1 or so.
    3. Use a good quality Engine Oil. It assures lesser wear and also reduces the danger from the carbon particles if any. Improves the life of the Engine.
    4. Keep the emissions from the engine in controlled limits.
    5. Use proper gear ratios and transmissions to get maximum torque from the produced power.
    6. Keep the overall weight moderate.
    7. Proper tyre Pressures and good quality tyres without much wear can help a lot improve the efficiency overall.
  • mutley
    @mutley-7zOklN • Jan 13, 2010
    Four things you can do / combustion effiency/volume effience/thurmal effiency and friction ( sorry about spelling as i write them as i see them, dixlexia long story)
    i will be loseing the 2nd piston ring to help reduce friction and polish the in side of the engine block and cutting the camshafts so 2 pistons fire togeather to get the touque up and lossing the 4 vavel head for a 2 vavle job from a cvh engine.
    will add more but getting my gril ready for school.
  • uttanoor harish
    @uttanoor-harish-xiM9nU • Jan 15, 2010
    nidheeshHow to improve the efficiency of an ic engine?๐Ÿ˜€
    To improve or to increase the diameter of the cylinder to improve the efficiency of an ic engine๐Ÿ˜
  • mutley
    @mutley-7zOklN • Jan 15, 2010
    uttanoor harishTo improve or to increase the diameter of the cylinder to improve the efficiency of an ic engine๐Ÿ˜
    The larger the volume the harder to fill VE would drop off. that's why thay use lost of small one's
  • ankit bapat
    @ankit-bapat-SXCtkn • Jan 16, 2010
    can anyone explain technical modifications in the engine to improve the efficiency not the precautions of using an engine to do the same
  • sangeethsreeni
    @sangeethsreeni-JR9IxY • Jan 24, 2010
    Efficiency of IC engine can be increased by providing a ionizing field in the combustion chamber making the combustion process more rapid. By this the actual cycle tend to the ideal cycle where efficiency is increased.......
  • ankit bapat
    @ankit-bapat-SXCtkn • Jan 26, 2010
    if we consider the problem in terms of thermodynamics
    then we should concentrate on how less we eject the heat energy from the exhaust and how can we utilize more heat to convert it into work
    i.e. heat at sink is reduced
    automatically the efficiency increases
    above concept is the base for all researches for improving the efficiency
  • sangeethsreeni
    @sangeethsreeni-JR9IxY • Jan 27, 2010
    the heat rejected to the sink can be reduced by the rapid burning,,,, ie giving less heat transfer period....
    This can be done by giving ionizing field....
    i think even a small projections on the electrodes can give the ionizing field, without much complication..............
  • chaudhary mayank
    @chaudhary-mayank-54d7tS • Apr 2, 2016
    we can use morden technologies , i mean we setup to increase oxygen % in air fuel mixtue ti increse efficiency ๐Ÿ˜๐Ÿ˜จ
