  • How to fetch data from existing table using PHP while I'm using XAMPP
    SatyaPHP
    SatyaPHP
    @satyaphp-ZcEgdV
    Updated: Oct 25, 2024
    Hi The_Big_k,
    I'm fresher in PHP and I want to learn PHP very well..............Please help.........
    I'm facing problem to fetch data from my existing table using below code:
    mysql_select_db("my_db",$con);
    $result = mysql_query("SELECT * FROM Persons");
    while($row = mysql_fetch_array($result))
    echo $row['FirstName'] . " " . $row['LastName'];
    echo "<br/>";
    mysql_free_result($result);
    And the Browser displayed the below error message
    Warning: mysql_fetch_array() expects parameter 1 to be resource, boolean given in C:\xampp\htdocs\learn\selectData.php on line 25
  • Whats In Name
    MemberFeb 3, 2013
    The warning you are getting shows that the query you tried to execute is facing some error and thus $result variable is storing FALSE and mysql_fetch_array() is getting a boolean as a parameter.To check for the error in query,use mysql_error() and tell us what browser displays.
  • Prasad Ajinkya
    MemberFeb 4, 2013
    I think your table might not have any rows, hence the boolean variable being returned (false).
    Typically before running the mysql_fetch_array() method, always check with mysql_num_rows($result) > 0 condition.
  • Manish Goyal
    MemberFeb 16, 2013
    This error will only come if sql query is not proper
    Is the table named Persons exists in DB?
