How to create a link to a website in a window?
gaurav.bhorkar
@gauravbhorkar-Pf9kZD โ€ข Oct 25, 2024
Example Window:
[โ€‹IMG]
When we click the link, the webpage should open in the default web browser.
Is there any Windows API function to do this?
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Jan 12, 2010
    Can anyone answer my question?
  • Prasad Ajinkya
    @prasad-aSUfhP Jan 12, 2010
    Hey Gaurav,
    Why not use a simple VB application to do this?
  • gaurav.bhorkar
    I don't know VB.
    I am creating a simple window program in C.
  • Prasad Ajinkya
    @prasad-aSUfhP Jan 13, 2010
    I am not so strong in C (perhaps others can help you). But suffice to say you have to create event handlers and events.
    What say folks?
    @thebigk Jan 13, 2010
    What programming language are you using? If its simple HTML:
    [url=https://www.CrazyEngineers.com/]CrazyEngineers[/url]
    The target attribute will tell the browser to open the page in a new window.
    Is that what you are looking for? ๐Ÿ˜•
  • Manish Goyal
    @manish-r2Hoep Jan 13, 2010
    Gaurav This is very interesting question that today you ask...i don't know much about it..but what my mind gives me this ..
    First of all you have to include <stdlib.h> file.in your code..Now use something like this
    Create a button on window ..when button will be clicked then this code will be executed
    system("browser.bat");
    here browser.bat will contain this name firefox.exe
    now when ever you click button then browser will open
    Now Question arises how to open a desired link..I will try this..
    I hope this will help you
  • Manish Goyal
    Gaurav just add this line to .bat file
    @echo off.
    start "link which you want to open"
    Just give it a try i am sure you will achieve what you want..and Please post your code here
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Jan 13, 2010
    The_Big_KWhat programming language are you using? If its simple HTML:
    Ya, this works in HTML but I am creating a simple window in C, which should link to a webpage.
  • gaurav.bhorkar
    goyal420Gaurav just add this line to .bat file
    @echo off.
    I'll try your method and get back on this thread.
  • gaurav.bhorkar
    @ Goyal
    The solution you suggested is not working. I think it works only for console applications.
    But a very intense Google search got this solution :-
    ShellExecute(hwnd, "open",
                    "https://www.example.com",
                           NULL, NULL, SW_SHOWNORMAL);
    Its a windows API function and it is working perfectly.
    Thank you guys for your suggestions.
  • Manish Goyal
    Gaurav can you please post your code?
    Actually i have tried this ..and this is working fine..
  • gaurav.bhorkar
    Here is the code snippet. I hope you know the contents of WinMain () function.
    LRESULT CALLBACK WindowProcedure (HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
        switch (message)
            case WM_DESTROY:
                PostQuitMessage (0);
                break;
            case WM_PAINT:
                 OnPaint (hwnd);
                 break;
            case [B]WM_LBUTTONDOWN:[/B]       /*To deal with the mouse click*/
                 OnClick (hwnd, LOWORD(lParam), HIWORD(lParam));
                 break;
            default:                      /* for messages that we don't deal with */
                return DefWindowProc (hwnd, message, wParam, lParam);
        return 0;
    void OnPaint (HWND hwnd)
         HDC hdc;
         PAINTSTRUCT ps;
         HFONT hfont;
         LOGFONT f = {0};
         HGDIOBJ holdfont;
         hdc = BeginPaint (hwnd, &ps);
         f.lfUnderline = 1;
         hfont = CreateFontIndirect (&f);
         holdfont = SelectObject (hdc, hfont);
         SetTextColor (hdc, RGB (0, 0, 255));
         TextOut (hdc, 0, 0, "Go to Google", 12);
         SelectObject (hdc, holdfont);
         DeleteObject (hfont);
         EndPaint( hwnd, &ps);
    void OnClick (HWND hwnd, int x, int y)
         if ((x>0) && (x<85) && (y>0) && (y<15))
                   [B]ShellExecute(hwnd, "open",
                   "https://www.google.com",
                   NULL, NULL, SW_SHOWNORMAL);[/B]
    This is the output.
    [โ€‹IMG]
