  • Having queries in ARM-SPI programming, plz clarify ?
    P Santhosh Kumar
    P Santhosh Kumar
    @p-santhosh-kumar-xUQgdt
    Updated: Oct 26, 2024
    Views: 2.0K
    Hai CEians,
    i am having doubt in ARM Programming given below:
    // SPI master initating function
    //link: <a href="https://www.electroons.com/ARM/" target="_blank" rel="nofollow noopener noreferrer">www.electroons.com</a>
    void MASTER_INIT(unsigned int spi_number)
    PINSEL0 = (PINSEL0 & ~(3 << 12)) | (1 << 12); // MOSI0 SPI0
    PINSEL0 = (PINSEL0 & ~(3 << 10)) | (1 << 10); // MISO0 SPI0
    PINSEL0 = (PINSEL0 & ~(3 << 8)) | (1 << 8); // SCK0 SPI0
    here i want to select SPI pins in PINSEL register, in LPC2148 ARM Processor, for ex. MOSI mean I have to make
    "PINSEL0=1<<12;" is enough.
    So, Why write the code like this:
    Is this the procedure to enable MOSI pin in SPI in LPC2148 processor?
    Plz clarify it.
    Any response is appreciated/..
  • a.alandkar
    MemberMar 7, 2014
    using this command you are defining that pin as a i/p pin.
