Have you ever know what is the use of Black Cylindrical shaped beads(ferrite bead) in Cables.
Have you ever know what is the use ferrite bead in Cables.
Hi friends you might have seen this cable often in all areas, but did you noticed why there is a cylindrical long shaped black bead kept in cables likes USB..etc. for what purposes it used.
Here the solution:
A black cylindrical shaped bead called as ferrite bead is a passive electric component that suppresses high frequency noise in electronic circuits.
It is a specific type of electronic choke.
Ferrite beads employ the dissipation of high frequency currents in a ferrite ceramic to build high frequency noise suppression devices.
It will reduce EMI( electro magnetic induction) inside the cables.
Here the solution:
Ramani Aswath
This video gives some basic details:Mr. ShameemHave you ever know what is the use ferrite bead in Cables.
lal#-Link-Snipped-#, EMI in this context is Electro Magnetic Interference. Electro magnetic induction is the generation of electro motive force when a conductor is subject to varying magnetic field, which is a different thing.
Anyway, a ferrite bead in a way helps maintain EMC - electromagnetic compatibility and reduce EMI - electromagnetic interference in a system. Ideally a system should be functional in a noise filled environment and shouldn't emit any noise that might interfere with other systems/sub-systems.
Ferrite beads, shielded cables, connector backshells, proper grounding, EMI gaskets, EMI filters, EMI honeycomb ventelation panels are some of the many ways followed to improve EMC and reduce EMI.
The Chinese smartphone giant, Xiaomi has announced two new smartphones/phablets to take on Apple's mighty iPhone 6 and iPhone 6 plus. Please do not confuse Mi Note and Mi Note...
Portable (mini ) biomass digesters, I will throw out this old and workable idea to
you new fresh minded genus's.
How about using your Electronic apps to enhance the bubbling...
Gone are the days when you'd have to find out creative ways to use Facebook at work without your boss or network administrators noticing. It was an open secret that...
Project Abstract / Summary : The project is choosen because of energy crisis all over the world.Nations are likely to turn toward more use of non conventional energy sources
This...
Refrigerants rule the world. Literally,
Refrigeration is Gods gift to man. It is totally unnatural and a highly manipulated act
by man.Life as you know it would not be possible...
