Getting Started With Raspberry Pi ? Here's Small Tutorial!
Kaustubh KatdareAh Python!
durga ch2-cents
1.RPi is just the CPU , that implies you would still have to procure input and output devices like keyboard, mouse, display
2. if you are fortunate, there might be a HDMI port to your computer, but that doesnot make it a Display suitable for using with RPi. The HDMI of your computer would generally be an OUT port as is your RPi's HDMI, that would make yu connect two OUT PORTs and you wont see anything happening. The ideal display would be something like a TV which has HDMI IN.
3.To be able to access RPi from your computer, once the RPi is initially connected to a display, ssh should be enabled and a static IP has to be assigned to the ethernet interface of RPi. As in all ix systems , it can be done in /network/interfaces file. -
Abhishek Rawal
Another way out is to purchase VGA to HDMI converter or DVI-D to HDMI Converter. Edit config file in the OS & then boot it.durga3.To be able to access RPi from your computer, once the RPi is initially connected to a display, ssh should be enabled and a static IP has to be assigned to the ethernet interface of RPi. As in all ix systems , it can be done in /network/interfaces file.
You can look at this for more detail : The Geeky Way– How To Display Raspberry Pi On VGA Monitor/TV ? -
durga ch#-Link-Snipped-# : right, but that would still need you to be connected to a display. I find accessing RPi remotely more convenient for that very reason, ofcourse unless someone wants to start the gui, but otherwise most of the configurations can be done via terminal without a gui.
Quoting from Gihub itself
ANTARES is an all-in-one buildsystem, aimed at baremetal targets. It is designed to be portable across a lot of MCUs and adding another MCU is trivial....
Indian Government Job website named niesbudnaukri.com has been launched by the National Institute Of Entrepreneurship and Small Business Development (aka NIESBUD). The job portal is aimed at providing information about...
If you are a true geek who's unhappy with the current choice of browsers that dominate the market viz. Chrome, Firefox, IE, Opera etc., and want a browser that's a...
The Chromebook is a stylish, Google-powered computer that is suited to casual users and low-demand tasks priced at an affordable range of $200-$250. A recent development attempts to bring the...
Great history awaits!
Its none other than Germany vs Argentina finale at Brazil kickstarting in a few minutes.Lets roll it
