French Evening at DSK Supinfocom’s Supinfomania 2011!
Get the taste of the French culture at Supinfomania 2011âs French Evening. Enjoy performances from French Street Dancers and more!
Venue:
Activity Area
DSK Supinfocom
Manjri, Near Loni Toll Plaza
Date/ Time:
Friday 2nd December 2011, 6-9 pm
Visit: #-Link-Snipped-#
Venue:
Activity Area
DSK Supinfocom
Date/ Time:
Quote:
Punkin Chunkin is the premier event for finding out who can throw and shoot a pumpkin the farthest – and the huge cannons powered by compressed air and built...
We have a 150MW steam turbine with specific steam consumption of 3.16 T/KWH.However actual steam consumption when measured is 3.4T/KWH. Steam pressure & temp is 140kg/cm2 540deg celsius respectively. What...
When turbine is operated at constant inlet steam pressure or variable pressure mode,steam consumption drops or increases. What is the reason & why?😕
hi guys,i have small doubt ....the doubt is regarding the performance issueconsider a table contains 100 columns ... i have created a view named "VIEW_A" with 100 columns and another view with 10 columns named its as VIEW_B...now i am extracting 10 columns of the data from the table using table like ------> select col1,col2,.....col10 form table same using view ----->select col1,col2,.....col10 form VIEW_Afor view with less columns -------------> select * from VIEW_Bnow in the above queries which one will exectue faster with less memory buffer.......... ?
How To Post On CrazyEngineers Forum
On CE Forum, you can either participate in any existing discussion or start a new discussion.
This short guide explains how to do it....
