high steam flow in turbine
We have a 150MW steam turbine with specific steam consumption of 3.16 T/KWH.However actual steam consumption when measured is 3.4T/KWH. Steam pressure & temp is 140kg/cm2 540deg celsius respectively. What are the probable reasons of high steam consumption?.Turbine is commissioned 3 months back.😡
When turbine is operated at constant inlet steam pressure or variable pressure mode,steam consumption drops or increases. What is the reason & why?😕
hi guys,i have small doubt ....the doubt is regarding the performance issueconsider a table contains 100 columns ... i have created a view named "VIEW_A" with 100 columns and another view with 10 columns named its as VIEW_B...now i am extracting 10 columns of the data from the table using table like ------> select col1,col2,.....col10 form table same using view ----->select col1,col2,.....col10 form VIEW_Afor view with less columns -------------> select * from VIEW_Bnow in the above queries which one will exectue faster with less memory buffer.......... ?
How To Post On CrazyEngineers Forum
On CE Forum, you can either participate in any existing discussion or start a new discussion.
This short guide explains how to do it....
The new CE-Forum is here to make things simpler for you.
Making it simple means having less options and thus less hassle. 👍
Whenever you want to quote another CEan's...
The "Watch Thread" Option is similar to "Subscribe to a Thread" Option.
Basically, this option can be used to get updates about the specific threads you are concerned about.
To...
