  • FLAMES code
    enthudrives
    enthudrives
    @enthudrives-VudUER
    Updated: Oct 27, 2024
    Views: 5.1K
    I think all of you would know the FLAMES game played by school students and teenagers.
    Using this game, they predict the relationship between two persons.
    F-Friends
    L-Love
    A-Affection
    M-Marriage
    E-Enemies
    S-Siblings
    Fist, you should take the two names:
    ABCD
    DEFA
    The common letters are stroked off(Shown in bold here).
    Then the remaining letters are counted. Here it is 4.
    Now, the calculation is done as follows
    FLAMES
    FLA ES
    F A ES
    A ES
    ES
    S
    So, the relationship is Siblings.
    Till counting the number of remaining letters, it is easy. But to get the relationship, the logic is a little complicated.
    Lets work it out here.
  • enthudrives
    MemberMay 16, 2009
    #include<iostream.h>
    #include<conio.h>
    #include<string.h>
    main()
          int f[6]={0,0,0,0,0,0},n,ch;
          char n1[100],n2[100];
          gets(n1);
          gets(n2);
          int l1,l2;
          l1=strlen(n1);
          l2=strlen(n2);
          int i,j;
          for(i=l1-1;i>=0;i--)
                if(n1[i]!='\0')
                for(j=l2-1;j>=0;j--)
                                    if(n2[j]!='\0')
        if(n1[i]==n2[j])
        n1[i]=n2[j]='\0';
        break;
          int count=0;
          for(i=0;i<l1;i++)
                           if(n1[i]!='\0')
                            count=count+1;
          for(j=0;j<l2;j++)
                           if(n2[j]!='\0')
                             count=count+1;
    cout<<"count is "<<count;
    This code counts the number of letters left after striking out the common letters.
  • shalini_goel14
    MemberMay 16, 2009
    Cool something different to code but does your code takes care of following scenario?
    If any of the two names are like following
    ABCDA
    DEFA
    Then in above case, first name has two 'A' s and second name has only one 'A' so do the program should cancel all 3 'A's or should cancel only 2'A's -one from each name?
  • enthudrives
    MemberMay 16, 2009
    no. only 2 'A's will be cancelled.
  • pradeep_agrawal
    MemberMay 16, 2009
    enthudrives
    The code currently does not gives the correct output. E.g., consider
    Name 1: Pradeep
    Name 2: Prad
    The output should 3 but the code give output as 2.
    The code need small correction for this:
    n1[i]=n2[i]='\0';
    need to be changed to
     n1[i]=n2[j]='\0';
    Also the check
    if(n1[i]!='\0')
    inside the first for loop is not required (though it does not create and issue).
    What if after removing common characters nothing is left-out (e.g., i compare Pradeep with Pradeep)?
    -Pradeep
  • enthudrives
    MemberMay 16, 2009
    pradeep_agrawal
    Name 1: Pradeep
    Name 2: Prad
    I get the output as 3 only. Try executing it once again.
    i edited
      n1[i]=n2[j]='\0';
    Thanks 😀
    And if nothing is left out, it will be considered as Friends 😀
  • pradeep_agrawal
    MemberMay 17, 2009
    Below is my code for the given problem statement.
    #include "stdio.h"
    #include "string.h"
    #define MAX_NAME_LEN 80
    #define INVALID 0
    #define VALID 1
    #define ASCII_UPPER_CASE_LOWER_LIMIT 65
    #define ASCII_UPPER_CASE_UPPER_LIMIT 90
    #define ASCII_LOWER_CASE_LOWER_LIMIT 97
    #define ASCII_LOWER_CASE_UPPER_LIMIT 122
    #define UPPER_CASE_LOWER_CASE_DIFF ASCII_LOWER_CASE_LOWER_LIMIT - ASCII_UPPER_CASE_LOWER_LIMIT
    typedef enum {EMPTY = 0, FRIENDS, LOVE, AFFECTION, MARRIAGE, ENEMIES, SIBLINGS} flames_t;
    /* Validates if name contains only alphabets */
    int validate_name(char* name, int len) {
      int i = 0;
      for(i = 0; i < len; i++) {
        if(!(((name[i] >= ASCII_LOWER_CASE_LOWER_LIMIT)
            && (name[i] <= ASCII_LOWER_CASE_UPPER_LIMIT))
            || ((name[i] >= ASCII_UPPER_CASE_LOWER_LIMIT)
            && (name[i] <= ASCII_UPPER_CASE_UPPER_LIMIT)))) {
          return INVALID;
      return VALID;
    /* Convert all characters to upper case */
    void convert_to_upper_case(char *name, int len) {
      int i = 0;
      for(i=0; i < len; i++) {
        if((name[i] >= ASCII_LOWER_CASE_LOWER_LIMIT)
            && (name[i] <= ASCII_LOWER_CASE_UPPER_LIMIT)) {
            name[i] -= UPPER_CASE_LOWER_CASE_DIFF;
    /* Eliminates common characters from both name by replacing them by '/0' */
    void eliminate_common_characters(char *name1, int len1, char *name2, int len2) {
      int i = 0, j = 0;
      for(i = 0; i < len1; i++) {
        for(j = 0; j < len2; j++) {
          if(name1[i] == name2[j]) {
            name1[i] = name2[j] ='\0';
            break;
    /* Count the number of characters in a string that has non-zero value */
    int char_count(char *name, int len) {
      int count = 0;
      int i = 0;
        if(name[i] !='\0') {
          count++;
      return count;
    /* Determine applicable flames based on number of uncommon characters */
    flames_t determine_applicable_flames(int count) {
      //declaring array containing each item of flames
      //all except 1 element will be one by one set to EMPTY based on calculation
      flames_t flames[6] = {FRIENDS, LOVE, AFFECTION, MARRIAGE, ENEMIES, SIBLINGS};
      //declaring variable to hold the result of calculation
      //initializing by EMPTY
      //if variable does not get reset, EMPTY will specify error in calculation
      flames_t result = EMPTY;
      //declaring a varibale to keep track of last deleted flames item
      int index = 0;
      int i = 0, j = 0;
      //checking number of uncommon characters
      //for 0 uncommon characters, flames should be Friends
      if(count != 0) {
        //five of six items of flames need to be removed
        //removing one item per loop
        for(i = 1; i <= 5; i++) {
          j = 0;
          while(1) {
            //considering flames items that still exist
            if(flames[index] != EMPTY) {
              j++;
            //if the current item is "uncommon character count" item
            //remove the item by setting value to EMPTY
            if(j == count) {
              flames[index] = EMPTY;
              break;
            } else {
              index++;
              //flames items have index from 0 to 5
              //reseting index to 0, when it's incremented after checking last item
              index = index % 6;
        for(i = 0; i <= 5; i++) {
          if(flames[i] != EMPTY) {
            result = flames[i];
            break;
      } else {
        //setting flames to Friends
        result = FRIENDS;
      return result;
    /* Display the applicable flames */
    void display_applicable_flames(flames_t flames) {
      switch(flames) {
      case EMPTY:
        printf("Error in calculation\n");
        break;
      case FRIENDS:
        printf("Friends\n");
        break;
      case LOVE:
        printf("Love\n");
        break;
      case AFFECTION:
        printf("Affection\n");
        break;
      case MARRIAGE:
        printf("Marriage\n");
        break;
      case ENEMIES:
        printf("Enemies\n");
        break;
      case SIBLINGS:
        printf("Siblings\n");
       break;
    int main() {
      char name1[MAX_NAME_LEN] = {0};
      char name2[MAX_NAME_LEN] = {0};
      int len1 = 0, len2 = 0;
      int count = 0;
      int i = 0, j = 0;
      //taking names as input
      scanf("%s", name1);
      scanf("%s", name2);
      //determining length of names
      len1 = strlen(name1);
      len2 = strlen(name2);
      //validating names
      if((validate_name(name1, len1) == INVALID)
          || (validate_name(name2, len2) == INVALID)) {
        printf("Invalid names\n");
        return 0;
      //converting all characters of string to upper case
      convert_to_upper_case(name1, len1);
      convert_to_upper_case(name2, len2);
      //eliminating common characters from both names
      eliminate_common_characters(name1, len1, name2, len2);
      //counting number of uncommon characters in both names
      count = char_count(name1, len1) + char_count(name2, len2);
      //determining the flames applicable based on the number of uncommon characters
      result = determine_applicable_flames(count);
      //displaying the applicable flame count
      display_applicable_flames(result);
      return 0;
    Compile the file with above code and run as:
    a.exe < input.txt > output.txt [on windows]
    a.out < input.txt > output.txt [on linux]
    Here,
    a.exe or a.out are the executables generated after compilation
    input.txt is the file containing two names for which FLAMES need to be calculated, e.g., if the names are Pradeep and Prad, then input.txt will be
    Pradeep
    Prad
    P.S.:
    1. The input can be in same line separated by space as
    Pradeep Prad
    2. The code considers that the maximum length of a name will be 79 characters. To change the maximum length modify the pre-processor directive MAX_NAME_LEN and recompile the code.
    output.txt is the output file containing result, for given example output.txt will contain
    Friends
    -Pradeep
  • enthudrives
    MemberMay 17, 2009
    can u please explain your logic?
  • pradeep_agrawal
    MemberMay 17, 2009
    I have modified the code to make some items self-explanatory. Also added comments to the code.
    The main logic to calculating FLAMES based on the calculated number of uncommon characters is written in function "determine_applicable_flames". Let me know if it need more explanation.
    -Pradeep
  • shalini_goel14
    MemberMay 17, 2009
    Please ckeck my program also in Java for this Flames thing. Any doubts or flaws in this, feel free to speak. 😀
     * FlamesProgram.java
     * Created on May 18, 2009, 9:54 AM
     * To change this template, choose Tools | Template Manager
     * and open the template in the editor.
    package myjava;
    import java.util.ArrayList;
     * @author shalinig
    public class FlamesProgram {
        public static void main(String[] args) {
            /* Specify any name1 -hardcoded */
            StringBuilder name1 = new StringBuilder("Pradeep");
            /* Specify any name2 -hardcoded*/
            StringBuilder name2 = new StringBuilder("Pradeep");
            ArrayList<String> flamesArrayList = new ArrayList<String>();
            int count = 0;
            System.out.println("Name 1: " + name1.toString());
            System.out.println("Name 2: " + name2.toString());
            name1.replace(0,name1.length(),name1.toString().toUpperCase());
            name2.replace(0,name2.length(),name2.toString().toUpperCase());
            if(!name1.toString().equalsIgnoreCase(name2.toString())){
                /* Loop to replace all common letters in both names with 1 */
                for (int i = 0; i < name1.length(); i++) {
                    for (int j = 0; j < name2.length(); j++) {
                        if (name1.charAt(i)!='1' && name2.charAt(j)!='1' && (name1.charAt(i) == name2.charAt(j))) {
                            name1.replace(i, i + 1, "1");
                            name2.replace(j, j + 1, "1");
                            count+=2;
                count=name1.length()+name2.length()-count;
                /* Adds the FLAMES into an arrayList */
                flamesArrayList.add("F");
                flamesArrayList.add("L");
                flamesArrayList.add("A");
                flamesArrayList.add("M");
                flamesArrayList.add("E");
                flamesArrayList.add("S");
                /* Loop that calculates Flames */
                for (int i = flamesArrayList.size(); i > 1; i--) {
                    int index = count % (i);
                    int temp = flamesArrayList.size() - index;
                    if (index == 0) {
                        flamesArrayList.remove(flamesArrayList.size() - 1);
                    } else {
                        flamesArrayList.remove(index - 1);
                    for (int k = 0; k <= temp && temp < flamesArrayList.size(); k++) {
                        flamesArrayList.add(k, flamesArrayList.get(flamesArrayList.size() - temp));
                        flamesArrayList.remove(flamesArrayList.size() - temp);
                        temp--;
                /* Finally arrayList is left with only one letter which determines flame */
                System.out.println("Flame in between is : " + determineFlameType(flamesArrayList.get(0)));
            }else{
                System.out.println("Both the names are same");
        /* Static method that returns the type of Flame based on the flame letter passed */
        public static String determineFlameType(String flameLetter) {
            String flameType = null;
            switch (flameLetter.charAt(0)) {
                case 'F':
                    flameType = "Friends";
                    break;
                case 'L':
                    flameType = "Love";
                    break;
                case 'A':
                    flameType = "Affection";
                    break;
                case 'M':
                    flameType = "Marriage";
                    break;
                case 'E':
                    flameType = "Enemy";
                    break;
                case 'S':
                    flameType = "Siblings";
                    break;
            return flameType;
    Output :
    Name 1: Pradeep
    Name 2: Pradeep
  • enthudrives
    MemberMay 17, 2009
    @ Shalini
    I am not good at Java. I cant understand anything. Seems like greek 😔
    If you dont mind, please do the same in C or C++. Please...
  • shalini_goel14
    MemberMay 17, 2009
    enthudrives
    @ Shalini
    Like you don't understand Java, I don't undestand C/C++. By the way if you don't understand anything in it, you can ask and better start learning Java.😀
  • pradeep_agrawal
    MemberMay 17, 2009
    shalini_goel14
    Shalini, i looked into the code, and it looks good to me. Just one correction, the code to remove common characters need some changes.
    - Consider names as "Pradeep" and "Pradeep". Here the number of uncommon characters is 0, whereas your code gives number of uncommon characters as 2.
    - To correct this, i feel you need to put a break statement inside the 'if' where you are comparing names.
    The thing i really liked in the code:
    1. Conversion of names to upper case before comparing characters (i validated names against both upper case and lower case but missed to consider this scenario while comparison 😔, i have now updated my code also 😉).
    2. Some optimization techniques used in the code while calculating flames type, e.g.,
    It's a simple way to determine the flames type to be removed.
    3. The use of existing API's.
    Below are few items where i feel the code can be improved (all in terms of optimization):
    1. While comparing names every time you are doing "name1.toString().toUpperCase().charAt(i)"
    Instead you can just convert the name to upper case and store the same so that every time you have to just call charAt(i).
    2. Instead of combining the strings and then calculating the count, the count for each name can be separately calculated and then added.
    3. The code
    for (int i = 0; i < newString.length(); i++) {
        count++;
        if (newString.charAt(i) == '1') {
            count--;
    can be changed to
            count++;
    4. The code to calculate flames type is of order n^2 and can be reduced to order n^2.
    -Pradeep
  • shalini_goel14
    MemberMay 17, 2009
    Hi Pradeep,
    Many thanks for the corrections. 😁
    Actually I made this program in very hurry, so could not think of optimized way(Ya ! can make it more optimized 😉) , but coming to your point no 3 in improvements required, I feel your piece of suggested code would give me the count for characters that are 1 though I wanted count of characters thar are not 1. Anyways , for this it would be better if I could count it in "if" block of changing value as 1.
    For same name checking, BUG, need to look into it. 😔
    Upper case thing, yes you are right I knew it, it can be saved but I just showed my laziness in doing so just for finishing off this code quickly. 😛
    Point no 4, I am not clear , you want to say optimization can be done from n[sup]2[/sup] to n[sup]2[/sup] ? 😒
    Good to hear suggestions from you. 😀
    PS: I have edited my last program accordingly.
    Thanks !
  • pradeep_agrawal
    MemberMay 17, 2009
    Ahhh, i too replied in hurry 😉.
    shalini_goel14
            count++;
    I actually mean
        if (newString.charAt(i) != '1') {
            count++;
    But the way you modified have the handling and currently calculating the count is also good.
    shalini_goel14
    Here i mean to say that optimization can be done from n^3 to n^2.
    -Pradeep
  • shalini_goel14
    MemberMay 18, 2009
    pradeep_agrawal
    Can you please explain how you got complexity as n[sup]3[/sup]. According to me, complexity is 2n[sup]2[/sup] ?
    Correct me if I have any wrong concept ? 😔
  • pradeep_agrawal
    MemberMay 18, 2009
    Why i said that it's of order n^3 because:
    1. The loop "for (int i = flamesArrayList.size(); i > 1; i--)" cause order of n.
    2. The inner loop "for (int k = 0; k <= temp && temp < flamesArrayList.size(); k++)" cause another order n, making total complexity as order n^2.
    3. The implementation of add/remove function of ArrayList itself is of order n, making total complexity to order n^3.
    -Pradeep
  • shalini_goel14
    MemberMay 18, 2009
    pradeep_agrawal
    -Pradeep
    Oh yes thanks for reminding me point no 3.
  • karty
    MemberMay 10, 2011
    #include<stdio.h>
    #include<conio.h>
    #include<string.h>
    #include<malloc.h>
    typedef struct flames
    char c;
    struct flames *next;
    }flames;
    char* relation(char ch);
    void main()
    char s1[20],s2[20],s3[20],s4[20],f[]={"FLAMES"},ch;
    int i=0,j=0,k=0,l1,l2,count=0,m=0;
    flames *head,*ne2,*ne3,*ne4,*ne5,*ne6,*temp,*p;
    char *relate;
    printf("\n\nEnter First Name:: ");
    gets(s1);
    printf("\nEnter Second Name:: ");
    gets(s2);
    strcpy(s3,s1);
    strcpy(s4,s2);
    for(i=0;i<(l1=strlen(s1));i++)
    for(j=0;j<(l2=strlen(s2));j++)
    if(s1==s2[j])
    s2[j]=-1;
    s3=-1;
    for(i=0;i<strlen(s3);i++)
    if(s3!=-1)
    count++;
    for(j=0;j<strlen(s2);j++)
    if(s2[j]!=-1)
    count++;
    printf("\n\n");
    puts(s3);
    puts(s2);
    printf("\n\nLetters left are %d",count);
    delay(100);
    printf("\nchecking for F L A M E S..............\n\n");
    /*Creating CLL for flames*/
    head=(struct flames*)malloc(sizeof(struct flames));
    ne2=(struct flames*)malloc(sizeof(struct flames));
    ne3=(struct flames*)malloc(sizeof(struct flames));
    ne4=(struct flames*)malloc(sizeof(struct flames));
    ne5=(struct flames*)malloc(sizeof(struct flames));
    ne6=(struct flames*)malloc(sizeof(struct flames));
    head->c='f'; head->next=ne2;
    ne2->c='l'; ne2->next=ne3;
    ne3->c='a'; ne3->next=ne4;
    ne4->c='m'; ne4->next=ne5;
    ne5->c='e'; ne5->next=ne6;
    ne6->c='s'; ne6->next=head;
    /////displaying CLL
    temp=head;
    i=0;
    while(i<6)
    printf(" %c",temp->c-32);
    temp=temp->next;
    i++;
    printf("\n");
    temp=head;
    while(m<5)
    for(i=0;i<count-2;i++)
    temp=temp->next;
    printf("\nDeleting %c",temp->next->c);
    p=temp->next;
    temp->next=temp->next->next;
    temp=temp->next;
    free(p);
    m++;
    ch=temp->c;
    printf("\n\tSo.....The Relation is :::::: ");
    relate=relation(ch);
    delay(500);
    puts(relate);
    printf("\n\n");
    char *rel;
    switch(ch)
    case 'f':
    return rel="FRIENDSHIP";
    case 'l':
    return rel="LOVE";
    case 'a':
    return rel="ATTRACTION";
    case 'm':
    return rel="MARRIAGE";
    case 'e':
    return rel="ENEMY";
    case 's':
    return rel="SISTER";
  • PraveenKumar Purushothaman
    MemberMay 10, 2011
    I am planning to work this out in PHP... 😀
  • synergynext
    MemberMay 11, 2011
    praveenscience
    sounds good 😁
    those who understand C can also easily understand it, atleast I beleive that 😎
    MemberMay 11, 2011
    PHP is similar to Unix Shell Programming... It uses echo and stuff... 😀
    MemberMay 15, 2011
    Hey CEans... PHP Version here... #-Link-Snipped-#
  • shabarinath
    MemberAug 2, 2011
    #include<string.h>
    #include<conio.h>
    #include<stdio.h>
    #include<conio.h>
    void main()
    char a[10],b[10];
    // int count=5;
    clrscr();
    cout<<"\n Enter Name:";
    gets(a);
    puts(a);
    int len=strlen(a);
    cout<<"\n Lenght:"<<len;
    cout<<"\n Enter another name:";
    gets(b);
    puts(b);
    int len1=strlen(b);
    cout<<"\n Length of Secong Name:"<<len<<"\n";
    for(int i=0;i<=len;i++)
    for(int j=0;j<=len1;j++)
    if(a==b[j])
    a=' ';
    b[j]=' ';
    for(i=0;i<len;i++)
    cout<<a;
    cout<<"\n";
    for(i=0;i<len1;i++)
    cout<<b;
    cout<<"\n Enter how many no's are visible to you:";
    int vis;
    cin>>vis;
    switch(vis)
    case 1: cout<<"sister";
    break;
    case 2: cout<<"Enemy";
    break;
    case 3: cout<<"Friends";
    break;
    case 4: cout<<"Enemy";
    break;
    case 5: cout<<"Friends";
    break;
    case 6: cout<<"Marriage";
    break;
    case 7: cout<<"Enemy";
    break;
    case 8: cout<<"Affection";
    break;
    case 9: cout<<"Enemy";
    break;
    case 10:cout<<"Love";
    break;
    /* char flamesstr[]="FLAMES";
    for(i=0;i<vis;i++)
    if(i==vis-1)
    if(flamesstr==' ')
    i++;
    flamesstr=' ';
    else if(flamesstr!=' ')
    flamesstr=' ';
    /* else if(count==0)
    break;
    else
    count--;
    goto x;
    // puts(flamesstr);
    getch();
    MemberAug 2, 2011
    Dude, use either C or C++. Don't use both... 😲
  • shabarinath
    MemberAug 3, 2011
    haha for jst for tme pass i have wrote that but for not any particular ...........
  • eternalthinker
    MemberAug 4, 2011
    I'm just linking the python version here 😉
  • gokulml
    MemberJul 29, 2015
    Here's my code:
    #include<conio.h>
    #include<string.h>
    void del(char *x,int y,int z)
    int i;
    for(i=0;i<y;i++,x++);
    for(i=y;i<z;i++,*x=*(x+1),x++);
    char flames(int x)
    int i,j=-1;
    char s[]="flames";
    while(strlen(s)!=1)
    for(i=0;i<x;i++)
    j++;
    if(j==strlen(s))
    j=0;
    del(s,j,strlen(s));
    j--;
    return s[0];
    void res(int x)
    switch(flames(x))
    case 'f':cout<<"Friend";
    break;
    case 'l':cout<<"Lover";
    break;
    case 'a':cout<<"Affection";
    break;
    case 'm':cout<<"Marriage";
    break;
    case 'e':cout<<"Enemy";
    break;
    case 's':cout<<"Sister";
    void grafix(int x)
    int i,j;
    clrscr();
    for(i=0;i<500;i++)
    for(j=0;j<x;j++)
    res(i);
    cout<<"\t";
    cout<<"\n";
    clrscr();
    void main()
    char a[20],b[20],c[40];
    int i,j,n;
    clrscr();
    cout<<"\nEnter your name: ";
    cin>>a;
    cout<<"\nEnter your lover name: ";
    cin>>b;
    grafix(9);
    for(i=0;i<strlen(a);i++)
    for(j=0;j<strlen(b);j++)
    if(a==b[j])
    del(a,i,strlen(a));
    del(b,j,strlen(b));
    i--;
    j--;
    strcpy(c,a);
    strcat(c,b);
    n=strlen(c);
    cout<<"\n";
    if(n==0)
    cout<<"Flames";
    else
    res(n);
    getch();
  • Srikar-350
    MemberOct 30, 2015
    enthudrives
    #include<conio.h>
    #include<string.h>
    main()
          gets(n1);
          gets(n2);
          int l1,l2;
          l1=strlen(n1);
          l2=strlen(n2);
          int i,j;
                if(n1[i]!='\0')
                                    if(n2[j]!='\0')
        if(n1[i]==n2[j])
        n1[i]=n2[j]='\0';
        break;
          int count=0;
          for(i=0;i<l1;i++)
                           if(n1[i]!='\0')
                            count=count+1;
          for(j=0;j<l2;j++)
                           if(n2[j]!='\0')
                             count=count+1;
  • Srikar-350
    MemberOct 30, 2015
    #include<conio.h>
    #include<string.h>
    main()
    int f[6]={0,0,0,0,0,0},n,ch,count=0;
    gets(n1);
    gets(n2);
    int l1,l2;
    l1=strlen(n1);
    l2=strlen(n2);
    int i,j;
    if(n1!='\0')
    if(n2[j]!='\0')
    if(n1==n2[j])
    n1=n2[j]='\0';
    count++; break;
    |*no need of two loops to int count=0;
    for(i=0;i<l1;i++)
    if(n1!='\0')
    count=count+1;
    for(j=0;j<l2;j++)
    if(n2[j]!='\0')
    count=count+1;
    count=l1+l2-(2*count);
