find bug in this vb6.0 code ?
safwan
@safwan-NH7W5Y โ€ข Oct 26, 2024
I have created a login form for connecting vb6 to oracle .The following code I have wrote in click event of button login.
Private Sub cmdlogin_Click()
Dim con As New ADODB.Connection
Dim constr As String
Dim username As String
Dim pwd As String
username = Trim(txtusrname.Text)
pwd = Trim(txtpwd.Text)
constr = "provider = MSDAORA;user id = username; password = pwd;"
con.Open constr
If con.State = adStateOpen Then
 MsgBox ("oracle connected")
 Else
   MsgBox ("oracle not connected")
 End If
End Sub
Here , we are taking username and pwd from user. when I run program I get error saying ""username or pwd invalid. but when I alter the code and use below code I get correct output why ? what is the reason ?
 constr = "provider = MSDAORA;user id = system; password = system;"
 con.Open constr
  Else
  End If
End Sub
  • safwan
    safwan OP
    @safwan-NH7W5Y • Nov 11, 2009
    Any buddy ?? Please solve this .
  • sookie
    @sookie-T06sFW • Nov 11, 2009
    Hi safwan,
    I guess the problem is in first case, you are trying to use 'username' and 'pwd' as user-defined variables while in second case 'system' is both username and passowrd for connecting to the database. So check if your first case work if I use it like following
    constr = "provider = MSDAORA;user id = "& username &"; password = "& pwd &";"
    I assumed that whatever username and password user enters from UI is valid one. ๐Ÿ˜€
  • safwan
    safwan OP
    @safwan-NH7W5Y • Nov 12, 2009
    Hay sokie I got your point and I tried it also but its not working .Its giving same errore .
  • sookie
    @sookie-T06sFW • Nov 12, 2009
    safwanHay sokie I got your point and I tried it also but its not working .Its giving same errore .
    What username and password , you are entering in your textboxes?
    Just a request for helping us in tracing the error- Can you display the value user is getting in 'username' and 'pwd' variable ? Try adding msgboxes for it and display the value of 'username' and 'pwd' you are getting in program. Also try to display entire 'constr' string in your program. What value it displays ?
  • safwan
    safwan OP
    Sokii I enter the username = system and password=system .
    Both are set by me for oracle 10 g. in my pc.
    Sokii when I entered the following code .
    Dim pwd As String
    constr = "provider = MSDAORA;user id = Trim(txtusrname.Text); password = Trim(txtpwd.Text);"
    MsgBox ("you have entered" + " " + "username as " + username + " " + "password as" + " "+ pwd)
    MsgBox (constr)
    con.Open constr
     Else
       MsgBox (pwd + userid)
     End If
    End Sub
    when I enter user name as "system" ( not in double quotes) and same "system" in password text box I get first message box as :
    "you have entered username as system password as system"
    In second messagebox I get following message :
    " provider = MSDAORA;user id = Trim(txtusrname.Text); password = Trim(txtpwd.Text)"
    Now what should I do .๐Ÿ˜ก ๐Ÿ˜”
  • Guttu
    @guttu-Udy454 • Nov 12, 2009
    safwanI have created a login form for connecting vb6 to oracle .The following code I have wrote in click event of button login.
    Dim pwd As String
    con.Open constr
     Else
     End If
    End Sub
     con.Open constr
      Else
      End If
    End Sub
    Ummmmmmmmmm..
    replace
    username = Trim([B]txtusrname[/B].Text)
    with
    username = Trim([B]txtusername[/B].Text)
  • sookie
    @sookie-T06sFW • Nov 13, 2009
    @safwan: Can you please try to change red coloured line in your following code with my line shown in first post?
    Dim pwd As String
    [COLOR="Red"]constr = "provider = MSDAORA;user id = Trim(txtusrname.Text); password = Trim(txtpwd.Text);"
    [/COLOR]MsgBox ("you have entered" + " " + "username as " + username + " " + "password as" + " "+ pwd)
    MsgBox (constr)
    con.Open constr
     Else
     End If
    End Sub
    Replace red colour line with following
    I couldn't understand why you are using Trim(txtusrname.Text) and Trim(txtpwd.Text) instead of using 'username' and 'pwd' variable. If you are not using these 'username' and 'pwd' variables then why saving textboxes value in them? I am not getting why you are putting dumb logics even if we are telling you how to correct it. Creating unnecessarily bugs for yourself and discussion for rest of us. ๐Ÿ˜•
  • safwan
    safwan OP
    @safwan-NH7W5Y • Nov 13, 2009
    sookie@safwan: Can you please try to change red coloured line in your following code with my line shown in first post?
    Dim pwd As String
    [COLOR=Red]constr = "provider = MSDAORA;user id = Trim(txtusrname.Text); password = Trim(txtpwd.Text);"
    MsgBox (constr)
    con.Open constr
     Else
     End If
    End Sub
    Sokii First of all I thank you for your Help .I am still student So I may commit mistakes for coding and logic. ( As I am not a professional).when I used your direction given in above quote I but its giving following message in first message I get same message second message box I get message as " False" title name as VBoracon(which is my project name) and third message box I get is
    "[Microsoft][ODBC Driver Manager] Data source Name not found and no defult driver found" .
    I used (txtusrname.text ) because I want to get user names entered by user .
  • gsxraddict
    @gsxraddict-r5vh86 • Nov 19, 2009
    Dim pwd As String
    constr = "provider = MSDAORA;user id = " & username & "; password = " & pwd & ";"
    MsgBox ("you have entered username as " & username & " password as " & pwd & ".")
    MsgBox (constr)
    con.Open constr
    Else
    MsgBox (pwd & " " & userid)
    End If
    End Sub
    Use the & when connecting strings.
  • safwan
    safwan OP
    @safwan-NH7W5Y • Nov 20, 2009
    Thanks GXRADDICT Your cod is working well Actually the & was missing so I did it and it worked. AThanks sokii and Guttu for your help.
  • sookie
    @sookie-T06sFW • Nov 20, 2009
    safwanThanks GXRADDICT Your cod is working well Actually the & was missing so I did it and it worked.
    Did I tell something in FRENCH ? ๐Ÿ˜
  • safwan
    safwan OP
    @safwan-NH7W5Y • Nov 21, 2009
    sookieDid I tell something in FRENCH ? ๐Ÿ˜
    I am sorry !! but ๐Ÿ˜ฒ But when I used your code It was not working and giving error so I thought its wrong but after posting my above post I got realized that it is same as what you have told . ๐Ÿ˜”
