  • Difference between comprator and opamp
    sonujain
    sonujain
    @sonujain-41NDsV
    Updated: Oct 26, 2024
    Views: 1.4K
    explain me the difference between the comprator and opamp using follwing example:
    1) if my v+ is 12v and my v- is 0v, input + is 3v and input- is 2 volt, what would be the output of the comparator and of opamp??
    2)if input+ is 2 volt and input- is 3v , what would be the output of camparator and of opamp??
  • imnitsy
    MemberJan 30, 2010
    A comparator compares the voltages and switches its output to indicate which voltage is larger.
    now let us consider the first problem:
    in case of comparator the output will be positive power supply i.e., +12 volts
    in case of opamp the output will be +1 volts
    second problem:
    in case of comparator the output will be negative power supply i.e,-12volts
    in case of opamp the output will be -1volts
    also you said that you apply 0volts at the negative power supply,
    i think it must be -12volts!!!
    also I am considering that the gain of the opamp is 1.
    please correct me if I am wrong!
  • nitin_sharma
    MemberFeb 1, 2010
    you have provided incomplete information. You have to specify at which level the gnd is.
    if it is at somewhere between the 12 and zero volts then only the opamp will work otherwise not.
  • sanks85
    MemberFeb 1, 2010
    hey sonu kala L. is right... if you have the grnd between 0 to 12v then only the ckt will work... and we can find out output by comparing the two terminals of op-amp for comparator
  • sonujain
    MemberFeb 2, 2010
    hey friends sorry for that .after that can you answer my question?
