Difference Between 1-Byte, 2-Byte and 3-Byte Instructions
Shailaja Tiwari
Shailaja Tiwari
@shailaja-tiwari-lKhGjd Oct 27, 2024
In this article, we’ll take a deeper look at the 1-byte, 2-byte and 3-byte instructions in computer architecture. We’ll also learn about the differences between them. Pay attention.
1-Byte, 2-Byte, 3-Byte Instructions
Computing and data processing are the result of a sequence of small tasks conducted by a processor. These tasks are based on instructions, which are the fundamental units of operation for a computer system.
They dictate what the computer's processor should do. Depending on the instruction set architecture (ISA) and specific computer design, these instructions can come in varying lengths.
This article will delve into the specifics of 1-byte, 2-byte, and 3-byte instructions, and outline the key differences between them.
Instruction Size and its Impact
A byte, in computing, is most commonly composed of 8 bits.
A bit, which is short for binary digit, is the most basic unit of data in computing and can have a value of 0 or 1.
Therefore, when we speak about 1-byte, 2-byte, or 3-byte instructions, we refer to instructions that respectively fit within 8, 16, or 24 bits of data.
The size of an instruction, that is, how many bits or bytes it spans, is crucial in several aspects:
  1. Instruction Complexity: The size of an instruction impacts its complexity because it determines the breadth of operations that can be encoded. For instance, a 1-byte instruction in an 8-bit architecture has a limited range of potential operations because there are only 256 (2^8) unique combinations of bits. Conversely, 2-byte instructions (16 bits) can encode a considerably larger set of operations (65,536, or 2^16, unique possibilities). This trend continues with 3-byte instructions, offering even greater complexity and potential operations. Therefore, more bytes can accommodate a wider variety of operation codes (opcodes), increasing the processor's versatility.
  2. Memory Footprint: The memory footprint of a program refers to the amount of memory it occupies. If a program is composed mainly of 1-byte instructions, it will take up less memory space than if the same program were written using 2-byte or 3-byte instructions. This is important when memory resources are limited.
  3. Instruction Cache Efficiency: The instruction cache is a component of the CPU that stores copies of frequently accessed instructions to improve speed and performance. The larger the instruction, the fewer of them can fit in the cache at any given time. Thus, a program composed of smaller instructions can lead to a higher cache hit rate, improving performance.
  4. Performance: The performance of a computer system is closely tied to the size of the instructions it uses. Larger instructions require more memory, can take longer to fetch and decode, and fit less efficiently in the cache, potentially leading to slower execution times. However, larger instructions can also perform more complex operations, possibly reducing the total number of instructions needed for a given task and thereby increasing performance.
  5. Addressable Memory: The size of an instruction can also dictate the amount of addressable memory in a system. Larger instructions can contain bigger numbers, allowing them to address a larger memory space.
  6. Data Handling Capability: Larger instructions can handle larger data sizes directly. For example, an instruction might contain a value to be used in an operation (an immediate value). If the instruction is larger, it can accommodate larger immediate values.
It's important to note that these factors all represent trade-offs, and the optimal instruction size may vary depending on the specific needs of the system and the tasks it performs. Computer architects must balance these considerations to achieve the desired performance and functionality.
1-Byte Instructions
1-byte instructions are compact, consisting of just eight bits of binary data. They are fundamental in many 8-bit processor architectures, like the Intel 8080 or the MOS 6502, which powered early personal computers such as the Apple I and the Commodore 64.
The structure of a 1-byte instruction depends on the specific architecture, but typically it includes an opcode, and sometimes an operand.
  1. Opcode: The opcode, or operation code, is a portion of the instruction that specifies the operation to be performed. It's essentially the command being given to the processor. With 1-byte instructions, the opcode must fit within the space of a single byte. This limits the number of unique opcodes, and thus the number of unique operations, that can be represented. Given that there are 256 unique combinations of eight bits, there can be at most 256 unique 1-byte opcodes.
  2. Operand: The operand, if present in a 1-byte instruction, is the portion of the instruction that represents the value on which the operation should be conducted. This could be an address in memory, a register in the processor, or an immediate value. In many 1-byte instructions, there is no room to include an operand within the instruction itself. Instead, the operand might be implied by the opcode, or the opcode might reference the next byte or bytes in memory as the operand. This method of referencing outside the instruction allows for a greater range of operand values but can require additional instruction fetches, slowing execution time.
The primary advantage of 1-byte instructions is their efficiency. With their small size, they allow for rapid execution and minimal memory usage.
Fetching the instruction from memory into the processor is a fast operation, and more of these small instructions can fit into the processor's instruction cache, which can also speed up execution.
Additionally, programs composed of 1-byte instructions have smaller memory footprints, allowing more programs or data to fit in a given amount of memory.
Despite these advantages, the simplicity of 1-byte instructions comes at a cost: limited functionality.
The number of operations and the range of operand values that can be represented within one byte are constrained.
This can lead to longer and more complex programs when a task cannot be accomplished with the available 1-byte instructions and must instead be broken down into multiple steps.
For instance, in a hypothetical 8-bit architecture, there may not be a 1-byte instruction to add a two-digit number directly, as there's not enough room in a single byte to represent both the opcode for "add" and the two-digit operand.
This operation might need to be broken down into multiple instructions: first loading the two-digit number into a register, then performing the addition.
Thus, while 1-byte instructions have their advantages, they come with inherent limitations. The choice to use 1-byte instructions, and the manner in which they are implemented in an instruction set, reflect trade-offs between efficiency, complexity, and functionality in computer architecture.
2-Byte Instructions
2-byte instructions consist of 16 bits of binary data, giving them more complexity and versatility than 1-byte instructions.
They are prevalent in 16-bit processor architectures, like the Intel 8086 and Motorola 68000, which powered the IBM PC and the original Apple Macintosh, respectively.
The additional eight bits in a 2-byte instruction provide room for more complex opcodes and operands.
  1. Opcode: Just as with 1-byte instructions, the opcode in a 2-byte instruction specifies the operation to be performed. The greater length of the instruction means that there can be more unique opcodes, allowing for a wider variety of operations. In particular, architectures with 2-byte instructions can often perform more complex operations in a single instruction, as compared to 1-byte instruction architectures. For example, a 2-byte instruction might be able to load a value from memory and perform an operation on it in a single instruction, where an equivalent 1-byte instruction architecture would require multiple instructions.
  2. Operand: The additional length of 2-byte instructions also provides more room for operands. The operand could be a larger immediate value, an address in a larger memory space, or a reference to a larger number of registers. This added space can reduce the need for additional instructions to handle larger values or address larger memory spaces, increasing the efficiency of programs.
Despite the added functionality, there are trade-offs when using 2-byte instructions. They take up twice as much memory as 1-byte instructions, increasing the memory footprint of programs and potentially decreasing the amount of memory available for data.
Fetching 2-byte instructions from memory can take longer than fetching 1-byte instructions, potentially slowing down execution. They also occupy more space in the instruction cache, reducing its efficiency.
Moreover, while 2-byte instructions can increase the computational power of a program, not all operations require such power.
Therefore, there might be wasted potential in cases where the full range of operations provided by the 2-byte opcode is not needed, leading to potential inefficiencies.
In conclusion, 2-byte instructions provide an expanded range of operations and a more considerable range of operand values compared to 1-byte instructions.
However, this expansion in functionality comes with increased memory usage and potentially slower execution times, representing a key trade-off in computer architecture.
The specific design of a processor's instruction set, including the use of 2-byte instructions, is driven by balancing these trade-offs to achieve the desired performance and functionality.
3-Byte Instructions
3-byte instructions are composed of 24 bits of binary data.
They provide even more complexity and functionality than 1-byte or 2-byte instructions and are utilized in some more advanced computer architectures, often as part of a variable-length instruction set.
The 24 bits of data in a 3-byte instruction provide ample room for even more complex opcodes and operands:
  1. Opcode: As with 1-byte and 2-byte instructions, the opcode in a 3-byte instruction specifies the operation to be performed. Because of the larger size of the instruction, there can be many more unique opcodes, allowing a much wider variety of operations. These operations can be even more complex, combining multiple simple operations into a single instruction or performing operations on larger data types.
  2. Operand: The extra space in a 3-byte instruction provides more room for operands. This extra space can accommodate even larger immediate values or addresses, potentially reducing the number of instructions required to handle large values or address large memory spaces.
Despite the advantages of increased functionality and complexity, there are also downsides to using 3-byte instructions.
The memory footprint of these instructions is larger, which means that programs composed of 3-byte instructions will require more memory space.
This increased memory requirement can also lead to longer instruction fetch times, as it takes more time to fetch a larger instruction from memory into the processor. This can potentially slow down execution.
Furthermore, because of their size, fewer 3-byte instructions can fit in the instruction cache at a time, compared to 1-byte or 2-byte instructions.
This reduces the cache's efficiency, potentially leading to more cache misses and longer memory access times.
Finally, just as with 2-byte instructions, there can be inefficiency if the full range of operations provided by the larger opcode is not needed.
Not all operations require the full complexity of a 3-byte instruction, so in some cases, the potential functionality of the 3-byte instruction could go unused, wasting memory space.
In conclusion, 3-byte instructions offer an even greater expansion of computational power and flexibility compared to 1-byte or 2-byte instructions.
However, they also require more memory and can lead to slower execution times due to longer instruction fetch times and less efficient cache usage. As with other aspects of computer architecture, the use of 3-byte instructions reflects trade-offs between performance, functionality, and efficiency.
The Trade-off
Overall, there's a trade-off between instruction size and computational functionality. Smaller instructions like the 1-byte instruction are more efficient regarding memory use and fetch time.
However, they provide limited functionality. As instruction size increases to 2-byte and 3-byte instructions, the range of operations that can be performed, and the size of data that can be handled, increase significantly, but so does the memory usage and fetch time.
It's essential to note that the modern computer processors used in everyday personal computers, such as those based on the x86-64 architecture, can have a variable instruction length, not just limited to 1-byte, 2-byte, or 3-byte instructions, but even going up to 15 bytes.
This flexibility allows these processors to balance the trade-offs between instruction size and computational functionality, thus enhancing the overall performance and efficiency of the computer system.
To summarize, the differences between 1-byte, 2-byte, and 3-byte instructions lie primarily in their complexity, memory footprint, and the range of operations they can perform.
Their usage depends on the specific needs of a computer system and the tasks it is designed to perform.
I hope this offers a detailed insight into the different instruction sizes. Let me know if you have more specific questions.
  • ashwin sarangula
    ashwin sarangula
    @ashwin-sarangula-Eb5r0N Jan 19, 2013
    shailaja revathiHI,
    well,i would like to share your words.
    since you are somewhat from my discipline i would rather like to ask you question .
    "what is the difference between 1-byte instruction ,2-byte instruction and 3-byte instruction?" .this question might sound somewhat easy but i am experiencing difficulty in understanding it.i hope you would help me and sorry for such a big story.
    hi shailaja, i would be glad to know whether you were talking about the opcodes ?
  • Shailaja Tiwari
    Shailaja Tiwari
    @shailaja-tiwari-lKhGjd Jan 19, 2013
    ashwin sarangulahi shailaja, i would be glad to know whether you were talking about the opcodes ?
    yes i am talking about the opcodes.
  • ashwin sarangula
    ashwin sarangula
    hey first tell me what do you
    shailaja revathiyes i am talking about the opcodes.
    hi shailaja, as you are asking this question , i hope you know some thing about opcodes. i will try to give answer to your question as per my knowledge.
    well , coming to the point, as we know that all the instructions are converted into the binary format right.now, for example,if we consider an hexadecimal number,it occupies 8 bits or 1 byte of space, if we have a combination of more number of such numbers, then the combine size of the instruction converted to binary code with be mutipled.
    this is just an example the same can be applied all types of microinstructions.
    thats what i feel from my perspective. even iam learning this presently, in my course, i would also like to know more about this..........
  • Shailaja Tiwari
    Shailaja Tiwari
    ok thanks. but why is it that in one byte instruction both the opcodes and operands are in the same byte and why is the case different with three byte and two byte instruction?someone said that in 1 byte the operand is present within the instruction itself/the register used for data transfer or other operation ,though i am not satisfied with her answer . i am still confused.need to know more about this.
  • rahul69
    rahul69
    @rahul69-97fAOs Jan 19, 2013
    shailaja revathiok thanks. but why is it that in one byte instruction both the opcodes and operands are in the same byte and why is the case different with three byte and two byte instruction?someone said that in 1 byte the operand is present within the instruction itself/the register used for data transfer or other operation ,though i am not satisfied with her answer . i am still confused.need to know more about this.
    Guess u r confused, but it is alright as it is a little tricky concept, also I am no expert so feel free to correct me . So lets see it thoroughly 😀.
    An instruction consist of two main parts : Opcode and operands, so the three troubling cases:
    One byte instruction: In this instruction, both opcode and operands are stored in single byte.(now u may ask why?), because opcodes in this category are simple (eg MOV,ADD etc.) and take less space than a single byte and operands are internal registers,and hence can be directly coded into instruction.
    Two byte instruction: Here the opcode occupy one byte. The operand occupy one byte too.
    Three byte instruction: Here opcode occupy one byte and operand two bytes. In this case operand is bigger and hence cannot be accommodated in single byte.
    Hope it clears ur doubt,😀. Feel free to ask if u face difficulty 👍
  • Shailaja Tiwari
    Shailaja Tiwari
    @shailaja-tiwari-lKhGjd Jan 24, 2013
    why does the exchange operation take place between the DE and HL pair only?why is BC pair not involved?
    please do help.
  • rahul69
    rahul69
    @rahul69-97fAOs Jan 24, 2013
    shailaja revathiwhy does the exchange operation take place between the DE and HL pair only?why is BC pair not involved?
    please do help.
    I think it is because, they are made that way. BC is used by instructions as a Byte Counter.
  • Shailaja Tiwari
    Shailaja Tiwari
    Could you please eloborate this point of yours as it has'nt solved my doubt.😨
  • rahul69
    rahul69
    shailaja revathiCould you please eloborate this point of yours as it has'nt solved my doubt.😨
    My answer was "they are made that way". which means that since BC was used as byte counter, so the people who made Assembly maybe decided to not to use it with DE and HL.
    Now I could be wrong because you were not specific as which assembly you are using, and in that "Exchange" were u talking about some exchange using xchg instruction, or were u exchanging using load and move operations??
