common emitter bjt
pradeep madhav
@pradeep-madhav-kuzmRN โ€ข Oct 26, 2024
hi
in a common emitter bipolar junction transistor when the forward bias voltage across the emitter base junction is increased (after the cut in voltage ) the depletion region across the emitter base junction in a npn transistor decreases ,so it increases the width of the base region (when compared to prior width of the base region) ,so now due to large width there should be increased number of electron hole recombination in the base region resulting in the (increase of base current and decrease of collector current to a small extent ) ,but actually why does the collector current increase across the collector emitter circuit
  • reachrkata
    @reachrkata-FOcqhH • Feb 18, 2010
    The secret lies in the very small thickness and very light doping of the base. With the base voltage, there are so many electrons in the base that there are much more left after recombination in the base. All this excess electrons just flows into the collector, since it is more positive than the emitter.
    -Karthik
    ๐Ÿ˜
