Car Volume Based Traffic Light System using IR sensor (Arduino)
can someone give me advice about the code for this project
this is my sample code
int r1 = 1;// pin for the LED
int g1 = 2;
int r2 = 4;
int g2 = 5;
int r3 = 7;
int g3 = 8;
int r4 = 10;
int g4 = 11;
int y0 = 13;// all yellow LED are connected in parallel
int timer = 7000;// set initial timer for the system after first boot
int isObstaclePinA = 3;// pin for the IR sensor
int isObstaclePinB = 6;
int isObstaclePinC = 9;
int isObstaclePinD = 12;
int var = 0;
void setup () {
pinMode(r1, OUTPUT);
pinMode(g1, OUTPUT);
pinMode(r2, OUTPUT);
pinMode(g2, OUTPUT);
pinMode(r3, OUTPUT);
pinMode(g3, OUTPUT);
pinMode(r4, OUTPUT);
pinMode(g4, OUTPUT);
pinMode(y0, OUTPUT);
pinMode(isObstaclePinA, INPUT);
pinMode(isObstaclePinB, INPUT);
pinMode(isObstaclePinC, INPUT);
pinMode(isObstaclePinD, INPUT);
void loop () {
switch (var) { // for enabling the switch command
case 1:
if (isObstaclePinA == HIGH);
digitalWrite(isObstaclePinB, LOW);
digitalWrite(isObstaclePinC, LOW);
digitalWrite(isObstaclePinD, LOW);
digitalWrite(g1, HIGH);// LED lights on
digitalWrite(r1, LOW);
digitalWrite(r2, HIGH);
digitalWrite(r3, HIGH);
digitalWrite(r4, HIGH);
delay(timer); // time the lights will turn on
digitalWrite(y0, HIGH);
delay(3000); // time the yellow LED will light
for (isObstaclePinA == HIGH; timer < 50000; timer + 5000); // for adding seconds in the timer every time the sensor responds
break;
case 2: // next case
if (isObstaclePinB == HIGH);
digitalWrite(isObstaclePinA, LOW);
digitalWrite(g2, HIGH);
digitalWrite(r2, LOW);
digitalWrite(r1, HIGH);
delay(timer);
delay(3000);
for (isObstaclePinB == HIGH; timer < 50000; timer + 5000);
break;
case 3:
if (isObstaclePinC == HIGH);
digitalWrite(g3, HIGH);
digitalWrite(r3, LOW);
delay(timer);
delay(3000);
for (isObstaclePinC == HIGH; timer < 50000; timer + 5000);
break;
case 4:
if (isObstaclePinD == HIGH);
digitalWrite(g4, HIGH);
digitalWrite(r4, LOW);
delay(timer);
delay(3000);
for (isObstaclePinD == HIGH; timer < 50000; timer + 5000);
break;
  • Abhishek Havanur
    @abhishek-34yGS7 Dec 10, 2016
    Joerel Bacanican someone give me advice about the code for this project
    int g1 = 2;
    int r2 = 4;
    int g2 = 5;
    int r3 = 7;
    int g3 = 8;
    int r4 = 10;
    int g4 = 11;
    int var = 0;
    void setup () {
    void loop () {
    case 1:
    break;
    delay(timer);
    delay(3000);
    break;
    case 3:
    delay(timer);
    delay(3000);
    break;
    case 4:
    delay(timer);
    delay(3000);
    break;
  • Abhishek Havanur
    May i know your project problem Statement?
  • Joerel Bacani
    @joerel-p6RhAq Dec 13, 2016
    can you help me do the code for this?
    this is how the system will work
    the IR sensor will count the no. of vehicle then convert it to time that the green light will turn on.
    I'm having trouble dealing with it
    thank you
