  • Best method to upgrade Ubuntu
    Kishan Gupta
    Kishan Gupta
    @kishan-gupta-IFXTPJ
    Updated: Oct 25, 2024
    Views: 1.3K
    HI, I have Ubuntu 12.10 installed on my system right now. Now I want to upgrade it to 13.04.
    But I am little confuse which method will be best to upgrade. My past experience was very bad with 12.04 to 12.10 upgrade, later I had to reinstall Ubuntu 12.10 and need to reinstall all the applications also... 😔
    I want to know what steps should I take before upgrade, so that same condition would not come again.
    Well, instability occurs when you upgrade the distro without purging the PPAs you've installed.For the safe & successful upgrade it is always preferred that all the applications which you've installed in the system are of the same version that is available in the Ubuntu's repository.
    Consider, In 12.04 the GIMP version of 2.6 is available in its repository but you added the PPA to enjoy the latest version of Gimp i.e. 2.8 ,So before the upgrade you have to Purge all the PPAs you have installed in the system & also uninstall all the applications that are not available in Ubuntu's repository.
    How to Purge PPAs ?
    Method 1 : Press "Ctrl+Alt+T" & Type
     sudo apt-get install ppa-purge
    To remove the desired PPA, the syntax is something like this :
     sudo ppa-purge ppa:respository-name/subdirectory
    For example If I wanna remove PPA for Gimp, it will look something like this :
     sudo ppa-purge ppa:otto-kesselgulasch/gimp
    This will Purge the PPA & will degrade the Application to the version equal to Ubuntu repository.
    This method is pain in butt when you've added 50's of PPAs !
    Alternate Method :
    Install application "Y-PPA-Manager". You've to add the PPA to install this application.
    Isn't it ironic that to purge the PPA you have to Add the PPA ?
    Anyways we have to do this for the ease !
    Open Terminal & Type :
     sudo add-apt-repository ppa:webupd8team/y-ppa-manager
    then,
     sudo apt-get update
    Finally,
     sudo apt-get install y-ppa-manager
    This will install the application.
    Once Y-PPA-MANAGER is installed, Open it :
    [​IMG]
    Click on "Manage PPAs".In it there will be options like Remove,Update,Edit & Purge PPA. Click on PPA you wanna Purge & hit on "Purge PPA" :
    [​IMG]
    A terminal will pop & Purging process will begin !
    One by one purge all the PPAs, but still Y-PPA-MANAGER PPA won't be removed.
    So, to remove Y-PPA-MANAGER PPA, just use Method 1 to remove this PPA.
    Once done all this, run
     sudo apt-get update && upgrade
    Let's Jump On Raring :
     sudo do-release-upgrade -d
    Your distro will be upgraded !
  • Kishan Gupta
    MemberApr 30, 2013
    Thanks #-Link-Snipped-#. I will try this. I can understand now why it is best to install a fresh copy of Ubuntu then upgrading a old Ubuntu 😔..... It should be more easy to upgrade Ubuntu as in every 6 months they are releasing a new OS.
    #-Link-Snipped-# Adding PPAs means you're living in bleeding edge,you'll never know when something gets wrong & your distro gets crashed & pops bloody bug errors.PPA-Purge is life-saver in this time.
    Upgrading Ubuntu is extremely easy if you are not tweaking too much by customizing/modifying files,Adding custom files/scripts,running custom Kernel or whatever.
    Tweaking & customizing is fun in linux distros & thus a linux user should know how to revert the changes.
    BTW dealing with PPAs is very simple thing.
    Just learn the basics of How to Add,Remove,Edit & Purge PPAs using Terminal (& even manually).
    Sometimes Terminal fails to Purge but if you know how how to do it manually,it can be a big plus.
  • Kishan Gupta
    MemberApr 30, 2013
    #-Link-Snipped-#, I have to learn lots of things yet. I will try this and let you know whether I successfully upgraded Ubuntu or not.
    One more thing here, I had removed Unity and currently using GNOME 3, should I need to install Unity again, for proper up-gradation?
    If you've installed GNOME using Gnome3 PPA in Ubuntu 12.10 then Yes you have to purge that Gnome3 PPA.
