  • amplitude modulation & side bands
    Sindhu Chowdary
    Sindhu Chowdary
    @sindhu-chowdary-tDAv1D
    Updated: Oct 25, 2024
    Views: 1.0K
    hi....
    actually as per the definition the output of the amplitude modulation has same frequency as that of the carrier..........
    bt if the frequency is constant then why are side bands supposed to be there?????
  • lokesh258
    MemberMay 30, 2012
    because there is a distortion in the frequency component even though frequency is constant
  • Sindhu Chowdary
    MemberMay 31, 2012
    lokesh258
    then if a question is asked like this........what is the frequency of the modulated wave with modulating frequency f1 and carrier frequency f2??????????
    is the answer f2 or f2+f1 and f2-f1??????
  • pratap singh, upendra
    MemberJun 5, 2012
    you cannot get a frequency on account of amplitude modulation. you will always get frequencies.
    it is because amplitude modulation does not result in a single frequency component. rather three distinct components are produced.
    The first component contains higher order frequency in terms of carrier frequency. this component is not useful because no message content resides in it.
    the other two components are of interest to us since they contain message signal; these components are f2-f1 and f2+f1. it is from these two components that the message signal is recovered through various demodulation schemes.
    so you always get a mixture of frequencies rather than a single frequency in the modulated wave as a result of amplitude modulation
