@dipen30-hGOPpa • Sep 15, 2009
Re: Dfs
1. Array size is fix and cannot change at run time,But in
link list we can create memory accoring to requirement.
2. In array we define but at the run time it is not used so
in that case memory is waste. -
@faizaan-l83FI7 • Sep 15, 2009
Re: Dfs
hi,
when we declare an array than the contiguous memory is allocated for that by compiler
so to declare a array of given size we require contiguous free space .But in case of linklist
we do not require contiguous free space each element will contain pointer that will give address of next free location.so linklist uses memory more wisely . -
@thebigk • Sep 15, 2009
DixsitaAdvantages of linklist over array??๐
Always provide a better title to your discussion threads.
*title edited* -
@saandeep-sreerambatla-hWHU1M • Sep 15, 2009
Faizaan is exactly correct.
Moreover, just try to write a program which sorts 5 elements of array using some method of sorting , like selection, merge, quick etc.
Then consider these 5 elements as linked lists and try sorting it , then you will get fewer combinations.
So effeciency is increased using Linked lists. -
@yashkumar-9FUcav • Sep 16, 2009
1. the memory distribution in linked lists is not contiguous unlike arrays, i.e., the memory is taken from the space available anywhere, and then a link is set with the previous node. However, arrays don not have this feature, and the memory distribution should be contiguous.
2. insertion and deletion in linked lists are easier than in arryas.
for e.g.- consider the list-
A--B--C--D--E----- so on
now, to remove any element, we can delete it, and link the elements linked to it together:
A--C--D--E--, B removed.
Here , we do not change the index or the position of the elements, but we just change the links. Similar is the case with additon.
However, in arrays, we have to change the index or the location each time we insert or delete any element. -
@sahithi-oJZaYj • Sep 16, 2009
yash.kumar1. the memory distribution in linked lists is not contiguous unlike arrays, i.e., the memory is taken from the space available anywhere, and then a link is set with the previous node. However, arrays don not have this feature, and the memory distribution should be contiguous.
Good answer. these are the two main differences.
WINNERS DONT DO DIFFERENT THINGS....THEY DO THINGS DIFFERENTLY........ -
@pushpen-mahawar-zxWxBz • Sep 18, 2009
Resizing or compressing an Array (removing ) takes linear time, Link lists are compressed and resized automatically, in constant time. Deleting would be the same speed, if you can live with "Null" elements in your array. If you have to compress the array afterwards, a list is your best bet.
Arrays are good for random access and good for sequential access (both are in constant time). Linked lists on the other hand are constant for sequential, but linear for random access.
The choice of which datastructure to use, depends entirely on the problem you're trying to solve. -
@rajayya-VhlXd8 • Sep 23, 2009
In the linked lists data be connected int the form of chain.that means the head of the one node shud be connected the tail of the another node.The data can be accessed from any where in the list.
In arrays data having the index and surely data can be accessed from 1st onwrds. -
Re: Dfs
Excuse me y don't u expand it.
