  • Manish Goyal
    @manish-r2Hoep Sep 27, 2009
    Re: Recursion..
    see recursion means a function calls repeatedly
    It uses system stack to accomplish it's task....as stack uses last in last out approach
    and when a function is called the controlled is moved to where function is defined which has it is stored in memory with some address this address is stored in stack
    second recursion is very interesting ....
    it reduces a time complexity of a program for eg
    say you have created a program for mergesort which uses recursion ie divide and conquer approach and insertion sort which uses normal programming
    now from time complexity point of view you will choose only merge sort to sort a array
    as it has time complexity of nlogn
    and insertion sort has n*n
    2:-it haS disadvantage also
    it involves a lot of memory wastage
    and very much typical concept to understand
