World’s Fastest Camera Shoots at 4.4 Trillion Frames Per Second
Researchers from the Keio University and the University of Tokyo in Japan have jointly developed the worldâs fastest camera that is able to capture consecutive shots with a frame interval of 4.4 trillion frames per second. It is thousand times faster than conventional high speed cameras which can capture an image every one-billionth of a second. Apart from the mind boggling frame-rate, the Sequentially Timed All-optical Mapping Photography (STAMP) camera has a high pixel resolution of 450âÃâ450 pixels. In order to understand the working of STAMP camera you need to first see how a conventional high speed camera works. A conventional high speed camera works on the pump-probe process where a pulse of light is initiated (pumped) at the object and then captured (probed). The drawback of this process is that it requires repetitive measurements to construct an image and during these measurements it often misses in probing non-repetitive events such as chemical reactions.
The STAMP motion picture camera made by the Japanese researchers uses the method of femtophotography to capture images in a single burst without the need of repetitive measurements. Femtophotography involves optical mapping of the target's time-varying spatial profile onto a burst stream of sequentially timed photographs with spatial and temporal dispersion. The researchers have already captured plasma dynamics and lattice vibration waves and hope that their camera will be put to use to study fast dynamics in photochemistry, spintronics , phononics, fluidics and plasma physics. Before launching the camera to the public the team is working on shrinking its size as currently is measures about a square meter.
Source: #-Link-Snipped-# Via #-Link-Snipped-#
Rajni Jain4.4 trillion frames per second with 450 × 450 pixels, Oh my gosh !!!
If we will have all the frames sequentially it will be clearer than the video.. 😁 -
Kaustubh KatdareTrillionth! Is that what you said? 😲
Chaitanya Kukde
MIT did cross the Trillion mark way back in 2011Kaustubh KatdareTrillionth! Is that what you said? 😲
#-Link-Snipped-# -
Anoop KumarSo you are saying that, to watch 1 second video of this camera with rate of 30fps will take 4650 years 😲😲😲😲😲😲
4.4 Trillion / (30fps * 3600 * 24 * 365) = 4650 years
Wishing our CEan a happy birthday @Aditya Deshmukh
I know that this topic has been discussed over and over again on news channels and newspapers in India over the last decade. But, in the hope of finding some...
Quote:
Kylie Simonds, an 11-year-old girl from Connecticut, has developed a backpack-based system that enables patients to receive chemotherapy without an IV pole.
Endquote
https://www.qmed.com/mpmn/medtechpul...-innovative-chemotherapy-device?cid=nl.qmed02
Desicrew Solutions Pvt. Ltd., a Chennai based Business processing outsourcing company, was founded by Saloni Mathotra, Ashwanth G and Manivanna J K in 2007. Desicrew was incubated by the Rural...
Quote:
Google and five other large companies are teaming up to build a cable under the Pacific Ocean that will deliver incredibly fast internet speeds.
The cable, dubbed Faster, will...
