Why Is Isolated Neutral Preferred In Some Turbines/Generators?
Dear engineers,
I need your help in analyzing this query:
Our plant consists of 11x 635 KW, 415V Waukesha gensets, 2 x 3.5MW,11KV wartsila gensets, 11 KV main bus for synchronization & 10 MW,11KV, 50 Hz gas turbine. The neutral of gas turbine is earthed against the manufacturers recommendations.
Now, a 2.7MV, 11KV, 50 Hz steam Turbine is being added to the system whose neutral is recommended to be earthed. but before taking this action the Neutral of existing Gas Turbine is to be un-earthed.
I am not asking from manufacturer's point of view but I am simply asking from synchronization point of view. Any questions will be welcomed!
THANKING IN ADVANCE 😀
Kaustubh KatdareThread moved to electrical/electronics engineering section.
Microsoft today confirmed that Windows 8 will have tight USB 3.0 integration. By 2015, it's expected that all the mainstream computing devices will offer tight USB 3.0 integration. USB 3.0...
iPhone 5 will truly be a global phone with support for both GSM and CDMA networks. This means a single device will be able to select from GSM and CDMA...
2.44 inch HVGA+ display
480 x 360 pixel resolution
800 MHz processor
BlackBerry 7 Operating System
Full QWERTY keyboard
5 megapixel camera with flash
Image stabilization,
Face detection
Digital zoom...
Blackberry Curve 9360 specifications are as follows -
800 MHz processor
5 megapixel camera...
Blackberry Curve 9370 specifications are as follows -
800 MHz processor
