Why can't we create folder named 'con' on desktop
Try it to believe it! This is something pretty cool...and unbelievable. .. At
Microsoft the whole Team, including Bill Gates, couldn't answer why
this happened! So Try it now , YOU CANNOT CREATE a folder by name" CON " or Try To rename the New Folder as CON Or con in a windows environment...It will not
Accept ... TRY IT AND REPLY IF ITS DONE
PrannyNot only CON, there are quite a many other name like LPT13, etc ehich cannot be used for folder name, and not only in desktop, they cannot be created anywhere.
Yet there is a way out, i am not sure if it works, but try it and reply here. Type CON in any text editor, copy it and then paste it to the name of the folder. I think this creates a folder named CON..... -
JerryGood to know that. Nice observation, ish_nalini π ! I searched the internet and came to know that a folder with name 'PRN' cannot be created anywhere inside windows.
I guess the reason is that those are standard device names. Is that ture?
Jerry -
ish_nalini
Really i dont know jerry , if any one found the reason for that they will be appointed in billy's company(bill gates).........JerryGood to know that. Nice observation, ish_nalini π ! I searched the internet and came to know that a folder with name 'PRN' cannot be created anywhere inside windows.
Jerry -
Anil Jainish_naliniReally i dont know jerry , if any one found the reason for that they will be appointed in billy's company(bill gates).........
There is nothing great in this..
There must be some function named as CON in folder creation library of windows. When we try to execute the command named as "CreateFolderName=CON" it get clashed with the config (function). so it changes it to by default new folder name, i.e. New Folder.
There are tons of bugs logged for WIndows, like:- some text is not displaying the NotePad or folder name.. Etc.
Even you can log a bug against this and help windows to resolve this.
This is just a Prognosis, Not very sure.. whats the reason is.
--Crazy -
Nehahey, thats amazing!! I never tried it out..good work ish_nalini!!
Keep the good work up!! -
aashimaYes. CON cannot be named as a folder and alss there is a similar problem as in we cannot rename the recycle bin. Does anybody has any idea of the reason behind?
Prasad AjinkyaCON, PRN, LPT13 are standard strings reserved by windows, hence you cant use them as folder names because had you created them, then the OS would be klueless as to wat to do .. execute the internal command (CON, PRN, et al) or open the folder :-D
As for renaming Recycle Bin, you can do that by editing the windows registry. -
instruite"con" was basically use in old DOS versions for "Console"
there are other reserved name too like
lpt1, lpt2, nul, com1, com2, com3, com4, clcok$, prn and may be many more -
akravikanthIt's Just like keywords in any programming language, for example you cant use if, else as variable names in C , java, etc.
CON,COM,LPT are just reserved strings, its similar to /dev/null in unix environment. -
A SudhaKarI came to known that we can able to keep folder names such as ,
Con, LPT1,LPT2, etc.
Like we can keep 26 names to folders.
Thats been hidden by developers , so some purpose.
Regards,
A.Sk... -
rahul dev choudI can make folder in all these names.......con ,lpt1, lpt2..etc named folder.
just follow these steps...
click on rename press alt+255
then u can able to make folder of these names.. -
sandmanActually you ll have to press the numbers of the number pad or else it wont work. That is, create a new folder, rename it CON but dont press enter yet. Hold down Alt and type 255 on the number pad and then press enter. (for laptop users, fress fn key and press the letter keys k-i-i to make use of the numberpad).
Well ALT+255 stands for a blank character in ASCII so it allows you to use this folder name. Well I consider this part "cheating" but there is one more technique which we can use.
Go to command prompt in your computer and type md\\.\\c:\\con [Note: you can give whtever path you want in place of c:] . Voila the folder is created. Now to delete it, it can done only thru the command prompt. Type rd\\.\\c:\con.
There you go. -
DEPrahul dev choudI can make folder in all these names.......con ,lpt1, lpt2..etc named folder.
i tried create folders with all these names by doing this but it didnt work.
please tell if there is any other way out?? -
crazyDEPi tried create folders with all these names by doing this but it didnt work.
just go to rename and press alt key plus 255...
that is the way to make folder like con, etc -
DEPcrazyjust go to rename and press alt key plus 255...
thanks crazy, finally i can create a folder with name CON -
DEPhey everyone,
you guys told us two methods for the creation of the folders namely "con","prn1" etc.
1. using alt+255
2. command prompt
i have observed a something. when you create the folder using "alt+255" technique,the folder is created with the namr "con " i.e the name con followed by a "space" while no such thing happens when you create it on the command prompt.
is my observation right???
ANYONE??? -
SatyajitHi! YA IT's TRUE that we can't creat a folder named "CON" but in my computer i have created A floder name "LPT13" on desktop.
&* also one thing by using alt+255 i m not able to creat any folder with name"con","lpt13"etc....π confused -
xheavenlyxbump****
TRY THIS: : :
create a new notepad file, empty.
just write "bush hid the facts" without quotes and save it, dont press enter.
see what happens π π π
again its just bush hid the facts
EDIT: Works only on XP. Not on Vista (IMO)
zeem_710πI can create a folder named "con" in windows.
Yes, :sshhh:that's true.
To create a folder with name con in C: drive type the following line in command prompt.
πmkdir \\.\c:\conπ -
mahulall this indicates that explorer.exe might be using the keyword "con" and is not able 2 create it. on the other hand we donot have such a problem with cmd prompt and can thus create a folder named "con". any comments on this any1??
Pegasus
We can rename the recycle bin folder.For this purpose you need to do some kind of modifications in registry.aashimaYes. CON cannot be named as a folder and alss there is a similar problem as in we cannot rename the recycle bin. Does anybody has any idea of the reason behind? -
vikrant thoratit is amazing it dosen't work. may be it is because of comp have no information about these words.
MaRoAt last it's Microsoft's software they're free to do what tehy want and you don't have the right to ask why.
raknahs2This is very blunt.
Please check the link #-Link-Snipped-#
CON and few more names are reserved device names in Windows. -
AnoopKumarwhile we r adding con folder through command prompt....we cant able to save anything to this folder.... actually wht we done here is open one of the system folder named con....and that is not a new folder
tildrahul dev choudI can make folder in all these names.......con ,lpt1, lpt2..etc named folder.
Hey dude.....U have given the wrong solution...
alt+255 is the Way of represention the SpaceBar..
so the name will become SpaceBar + Con and con....
But Actually we can give the name to any folder as con or lp1,pl2 & blah blah.......
Just u have to Use the Unlocker software...
Unlocker Sodtware is used to delete/move/rename the folder(s) or file(s)....
Here is the link....
Download:
Enjoy....π -
Ashraf HZOk.. what IS the obsession of trying to add the folder con anyway? *sigh* engineers...
Kaustubh KatdareYeah, I've been wondering about this too. Looks like suddenly everyone wants to create 'CON' on their desktop π . Btw, the title gets us some good traffic!
xheavenlyxHaha, nice! I think we crazy eng, are curious to know.
archit_p_vthere r so many different folders which can be created by a small change in registery.
PensuNice observation.....well i think the reason behind is as we can't use keywords as variable names in languages same is in the case of windows.
Manish Goyalcom,con,lpt are name of built in dos drivers
you can't use it...
of which 'com' is used of serial port
lpt is for printer.
correct me if i am wrong? -
pratik.itworldIn MS-DOS, several special "device files" were available to aid in performing certain tasks, such as clearing the screen or deleting extraneous output from a program. In order to maintain backwards-compatibility, all versions of Windows up to and including Windows Vista will refuse to allow you to create a file with these "reserved" device file names. The following file names are reserved:
- CON
- PRN
- AUX
- NUL
- COM1
- COM2
- COM3
- COM4
- COM5
- COM6
- COM7
- COM8
- COM9
- LPT1
- LPT2
- LPT3
- LPT4
- LPT5
- LPT6
- LPT7
- LPT8
- LPT9
saurabh2486nice work keep it up
great -
Chaitali SumitaxheavenlyxTRY THIS: : :
now you try this....when you are using the word bush...then you are getting 9 boxes according to your procedure......but you now try the same using any other name having even no of letters and make it sure that its more than 4 letters.....each time you increase two letters.. 1 box is increased....hence bush is not mandatory ...it can be any name.....and i dont think that this is possible for any name containing odd no of letters.............
if you know the answer then please do share it soon.........
PROUD TO BE AN CEAN -
shruti palodHi
yes we cant create folder named con or con1 , lpt1,con2........etc coz I think this is ms-dos stuff.But it can be created through command prompt.
but I dnt know the exact reason behind this.π -
Chaitali Sumitaxheavenlyxbump****
TRY THIS: : :
hiii.......can you please tell me the reason, why we cannot apply it in microsoft word???why it is only applicable to notepad??
eagerly waiting for your answers...
proud to be a CEAN -
Amitrockstari an make a folder name con
it is used by dos -
ankesh.cs2007yes we can create con named folder on to our desktop by renaming it with con and followed by alt+255.
and here it is con named folder....
these settings can be applied to other names also.... -
Rahul74we can't create a folder by a name CON as in DOS we are using console based system which doesn't allow to create such type of folder.
another reason is that, due to the name of Control Panel, whose starting words are CON in which Window dosen't allow to name a folder as CON............
think about it..... u all.... -
sasikala gandhiJust create a new folder and go to rename type con and hold alt and type 0160. You can create folder named con.
neeleshjsinghyou can create LPT as a folder in W7 and rename recyle bin as a CON it works
PraveenKumar PurushothamanCON, LPT, COMx are all reserved names of Microsoft Operating System...
synergynextvery old topic. Still, if anyone is still struggling to create a CON folder in C drive, try creating a batch file with following entry:
@echo off
mkdir c:\con\
run this bat file and refresh. CON folder gets created!
If you want to delete this folder, change the bat file entry:
@echo off
rmdir c:\con\ -
yoginavaleIn Windows, Con must be a library function which won't allow other stuff to be named similar.
PraveenKumar PurushothamanYou won't be able to delete the file by hand... π
If you want to delete, you need to do so only by rmdir! π² -
yoginavaleYaa i know the code , that is rmdir c:/con/
Right naa ? -
Mr.DonNice Topic. Didn't know till now π
abhimanyu sareeni can name folder con....ask me how,,at my email id
abhimanyu sareenits not impossible.....i have made it possible..yes only pressing 4 keys u can name folder con
theinamCON
PRN
AUX
CLOCK$
NUL
COM1
COM2
COM3
COM4
COM5
COM6
COM7
these are also not accepted by any folder at any where ππ -
Kaustubh KatdareClosing the thread.
Hi CEans!
Brian Huyser, founder of Symmetric Inc., USA and the man behind One Billion Bulbs talked to Crazy Engineers about his project.
Here is your chance to shout your...
I recommend the book 'Siddhartha' by Hermann Hesse. I'd appreciate if anyone who has read this books puts his or her thoughts in this discussion thread.
Jerry
This shouldn't take much time. I had fun solving this -
Jesse James' lesser known brother, Eddie has also decided to take up robbing
banks for a living. He is...
Hey Vinitg
Happy birth day from CE...:myparty::myparty:π
Enjoy
--Crazy
well there is a particular folder whose contents i want to hide...people suggested i download some software for this....but one of my friends suggested i can do this by changing...
