  3. Groups >
What’s the Difference Between Vibration Sensors?
Question asked by Ramani Aswath in #Coffee Room on Aug 21, 2018
Vijay Khatri
Vijay Khatri · Aug 21, 2018
Rank E1 - BEGINNER
An accelerometer measures a quality of acceleration, not necessarily vibration. But vibration sensors, which measure a quantity of acceleration and are therefore a type of accelerometer, are by definition accelerometers. A vibration sensor typically contains a piezoelectric crystal element bonded to a mass.
Addy smith
Addy smith · Aug 28, 2018
Rank D3 - MASTER
There is no real Difference But Older vibration sensors sensed position or velocity. Newer ones tend to use a MEMS accelerometer to detect vibrations. Accelerometer-based vibration sensors often capture acceleration data at a high rate. The built-in DSP uses a bandpass filter to eliminate the very high-frequency noise and to eliminate the low-frequency accelerations that are of little interest when it comes to detecting vibrations.  Here it is the low-frequency accelerations that are of primary interest. When it comes to detecting acceleration, the vibrations are just noise that are best eliminated at the source.
Vijay Khatri
Vijay Khatri · Apr 20, 2020
Rank E1 - BEGINNER
Follow this tutorial to you can learn a lot about testing here: https://www.bitdegree.org/course/selenium-tutorial
Click to Log-In or Sign-Up
