  3. Groups >
What is process design and piping design?
Question asked by Divya Marelli in #Mechanical on Dec 30, 2019
Divya Marelli
Divya Marelli · Dec 30, 2019
Rank E2 - BEGINNER
Is piping design and process design useful for mechanical engineering students to get design engineer job
Posted in: #Mechanical
Vinay Mishra
Vinay Mishra · Jan 12, 2020
Rank C1 - EXPERT
Process design: It is a part of chemical engineering. It is an activity to determine the workflow, needs, and implementation requirements of a particular process. In simple words, 'Designing the layout of a process'.
Piping design: It is also a part of chemical engineering. It is the development of efficient piping processes to find out the best way to transport fluids or gases.
Process designing is more beneficial for the job of design engineers because the piping design is limited to some applications related to chemicals.
Durgesh srivastava
Durgesh srivastava · Jan 16, 2020
Rank C3 - EXPERT
Process Design can be properly done and executed only with adequate and correct design data. This should include as a minimum the chemical and physical characteristics of chemicals, the reaction characteristics, including mechanism, kinetics, and thermal data for all likely reactions
Piping design is  comes in mechanical engineering branch. It comes under mechanical engineering and chemical engineering. It can be specifically for oil gas refinery and power piping.
Click to Log-In or Sign-Up
