  3. Groups >
What are the unique IOT project ideas?
Question asked by Durgesh srivastava in #Coffee Room on Jan 14, 2020
Durgesh srivastava
Durgesh srivastava · Jan 14, 2020
Rank C3 - EXPERT
What are some unique IOT based project ideas for engineering students? Please suggest.
Posted in: #Coffee Room
Kaustubh Katdare · Jan 14, 2020
Rank A1 - PRO
Internet of Thing or IOT is an interesting domain. Let's look at some of the project ideas in the IOT domain that engineering students can work on -
1. Athlete Performance Tracker
Your engineering project could develop a performance tracker for athletes. The device could make use of accelerometers, gyroscopes, accelerometers, temperature, moisture sensors to track athlete's movements and record them in real time. It could transmit all these measurements in real time to trackers and monitoring systems.
2. Smart Home Security System
Smart home security system could make use of a mesh of sensors mounted across strategic locations that track the movements of the people. It could make use of video cameras to monitor personnel and inform concerned authorities.
3. IOT Based Traffic System
Smart cities require proper traffic monitoring systems. IoT based traffic system would make use of smart sensors to track the movement of four-wheelers and two-wheelers on road and inform the traffic controllers. It could be used to operate the signals on the road and also relay the information to mobile applications.
I think these could get you started. Will add more later. Let's wait for more project ideas from fellow engineers.
Ashraf HZ
Ashraf HZ · Jan 15, 2020
Rank A2 - PRO
IoT Project Idea: Solar Powered Disaster Radio using Mesh Networking
There is an interesting IoT project I recently came across called Disaster Radio. It is a solar powered wifi access node that uses LPWAN (low power wide area network) to communicate with other access nodes using mesh networking. This is in case during a natural disaster and the telco network is down, emergency communication can still be established between these nodes across a very large area.
Some ideas to consider:
- Low cost component to make it affordable to mass produce
- Low powered electronics to run under solar power
- Tough enclosure to endure outdoor conditions
- Limited size of embedded computing capability
- Bandwidth limitation of LPWAN, so need to think about what suitable protocols to use
Would be good for engineering students to try fabricate this solution for their communities.
Link to hardware info & source codes: disaster.radio | a disaster-resilient communications network powered by the sun
Click to Log-In or Sign-Up
