Vb 6.0
I have done the following code for binary search.But all the time Its showing match not found even if the number is present in the array😔
Dim a As Integer
Dim i, j, k As Integer
Dim numbers(20) As Integer
Private Sub Command1_Click()
j = InputBox(" enter the number of elements in the array")
For i = 0 To j - 1
k = InputBox("enter the number:")
numbers(i) = k
Next i
MsgBox ("numbers successfully inserted")
a = InputBox("enter the number to be searched")
search12 (a)
End Sub
Private Function search12(b As Integer)
Dim Min As Integer
Dim Max As Integer
Dim Mid As Integer
Min = 0
Max = UBound(numbers)
Do While Min <= Max
Mid = Int((Min + Max) / 2)
If b = numbers(Mid) Then
' we have a match
MsgBox ("match found")
Exit Function
ElseIf b < numbers(Mid) Then
Max = Mid - 1
ElseIf b > numbers(Mid) Then
Min = Mid + 1
End If
Loop
'If (Min > Max) Then
' if we get here, the state was not found ...
MsgBox ("match not found")
'End If
Exit Function
End Function
Dim a As Integer
For i = 0 To j - 1
numbers(i) = k
Next i
search12 (a)
End Sub
Dim Min As Integer
Dim Max As Integer
Dim Mid As Integer
Min = 0
Do While Min <= Max
' we have a match
Exit Function
Max = Mid - 1
Min = Mid + 1
End If
Loop
'End If
Exit Function
End Function
Manish GoyalCan you post any example input for this program?
Here i mean array -
whiz.kid.aniket@samaira are you using ActiveX dll?
samaira
no m not using activex dllwhiz.kid.aniket@samaira are you using ActiveX dll? -
samaira
like e.g i gave input as 1,2,3,4,5,6 for n=6 and searched for 3goyal420Can you post any example input for this program?
Here i mean array -
Manish GoyalDo 1 thing
remove last condition
and add print statement or whatever used in vb to display output in order to display value of mid and tell me the output
Hello friend's,
Many of engineering college student have girl friends.
But there is also some student who doesn't(Reason most of the student have EGO problem he didn't like to start...
I am using Mozilla Firefox and i am not able chat on CE-Conference Chat. My mouse pointer doesn't change into cursor. Try to fix the problem.
I have new Micromax MMX 300C EVDO modem from BSNL. It works perfectly in windows platform. Username (cdma) & password (cdma) is also correct which allows to connect to internet....
i am giving a supply to a system where in place of U,V,W supply i am giving U,U,V supply to a system what will be the vectorial current representation of...
Hello,
Every body Esp. "CE - Newbie" could you help me devloping
remot controler
I am A computer Science student and now I am pursuing my MSc in Prague
If...
