USB 3.0 New Power Delivery Specifications
The USB 3.0 promoter group is planning to announce the new USB 3.0 power specifications. The new specs will extend the usage and capabilities of cable bus power in USB applications. Existing USB applications connectors will be able to deliver more power and co-exist with the USB battery charging 1.2 specs. The key characteristics of the new specs are as follows -
USB 3.0
Chairman of USB 3.0 Promoter Group, Mr. Brad Saunders says that the growing industrial adoption of USB requires that USB Bus Power to charge a wide range of electronic devices. With the new USB 3.0 specs in place, it would be possible to charge a netbook PC with USB. The power delivery specs will be made available for the industry review by the end of this year.
Source: USB Press (PDF)
[*]Compatibility with existing specs related to cables and connectors
[*]Voltage and Current negotiations over USB power pins
[*]Higher voltages and currents to deliver up to 100 Watt power
[*]Source of power delivery can be switched without changing the cable direction
[*]Work with both USB 2.0 and USB 3.0 battery charging specifications.
USB 3.0
The US Space agency, NASA, declared funding of $100,000 one-year grants to 30 new projects falling under the NASA Innovative Advanced Concepts (NIAC) program. Based on their potential to enhance...
We are a bunch of "Crazy" people here having our own say on government related matters. Well, not anymore. We are required to keep our so-called-opinions to ourselves (This one's...
NuCaptcha is a startup that's promising newer levels of protection to websites from spammers. Instead of showing static images with letters and numbers, NuCaptcha uses advanced video technology to generate...
Engineers at Illinois University have developed an electronic device platform that integrates with your skin and measures various parameters for medical diagnosis, sensing, communications and for human-machine interfaces. Engineers were...
Scientists at the NIST (National Institute of Standards and Technology) have found a way to manipulate the properties of two electrically charged atoms simultaneously by entangling them using microwave technology....
