Unable To Play Videos Which Are Downloaded Using IDM (Internet Download Manager)
I use internet download manager to download youtube videos and other sites video. i have been using IDM for past 2 years, but from past 2 month i have a problem - i am able to download videos, after download completed and i open the video using vlc player but video doesn't play. can anyone help me to resolve this issue? thanks for you reply......
Abhijit DeyTry reinstalling the software. If this doesn't help then upgrade it to the latest version. If it still doesn't help, then you are probably using a pirated version, which is many cases have bugs. I would recommend you to buy it, great piece of software!
Abhishek Rawal
Now, you can download videos but unable to play the video from vlc.micheal johnI use internet download manager to download youtube videos and other sites video. i have been using IDM for past 2 years, but from past 2 month i have a problem - i am able to download videos, after download completed and i open the video using vlc player but video doesn't play. can anyone help me to resolve this issue? thanks for you reply......
Which probably means that the fault lies in vlc player & not IDM.
However,I recommend :
- Play videos (which are already stored in computer & not downloaded using IDM) using vlc.
- If video plays then problem lies in download manager.
- If video doesn't play then vlc is corrupted (solution : reinstall vlc)
I hope this solves your problem. -
Anil Jain
Did you try running the video using any other video player?
If not, re-install / repair the IDM.
-CB -
Nayan GoenkaCalm down everyone, the issue is not what you all think so, Since past two months, youtube has started to store the video and audio parts of any file separately. So when you download anything from youtube, instead of the .flv now you get .mpa and .mp4 which are two parts of same file. To run videos you now have to download both separetely, this can be done by keeping close eye on IDM-popups for mp4 and mpa, then compile both using some mixer to create one file which supports the algorithm of youtube to demix them, and then you have a .flv file which can be played.
So basically instead of .flv you now have
.flv = .mp4 + .mpa
and also you cannot play these two formats separately if crazy ideas pop in your brain as they are siamese twins, useless without the other. 😛 -
Abhijit DeyThe best way I found in downloading videos from from YouTube is using Firefox Browser with an add-on called flash video downloader. This is a perfect alternative.
Abhishek Rawal
#-Link-Snipped-#Nayan GoenkaSo when you download anything from youtube, instead of the .flv now you get .mpa and .mp4 which are two parts of same file.
FLV & MP4 are not same File containers.
I repeat.
FLV & MP4 are not same file containers.
FLV is proprietary container developed by Adobe.
While MP4 is standarized by ISO in MPEG-4 family.
So logically again it's proved that .FLV =/= .MP4 + .MPA
PS : I have been downloading all youtube videos from #-Link-Snipped-# in MP4 format since last 3 years. -
Nayan Goenka
Read between the lines, my point was, instead of a video in one format like .flv or .mp4 or .avi, youtube has started divinding its files into two parts.Abhishek Rawal#-Link-Snipped-#
I repeat.
or in more simple terms,
5 oranges + 4 apples = 1 basket
this does not mean
5+4=1
duh.. 😨 -
Abhishek RawalLOL.
Youtube has always provided multiple formats.
Earlier IDM used to provide only .flv format,so you thought "Youtube provides" only flv.
Now,In latest patch IDM provides choice to download the video either in flv or mp4,so you think "Youtube provides" an apple with an orange.
Okay,Copy any youtube HD video url in #-Link-Snipped-# & you'll see it provides : MP4,avi,flv & even mp3.
So,does it mean that Youtube stores MP4,AVI,FLV in different locations ?Hell I doubt it!
What I mean is : It's nothing to do with Youtube,This is totally software end.Which in your case : IDM.
It would be nice of you if you link the "official blog or article" saying that Youtube stores audio & video data in different location. -
micheal john
you are right, when i IDM-popup it is showing MPA and MP4 format files not flv. But 1) what is the reason for youtube to separete audio and video files into two separete format? andNayan GoenkaCalm down everyone, the issue is not what you all think so, Since past two months, youtube has started to store the video and audio parts of any file separately. So when you download anything from youtube, instead of the .flv now you get .mpa and .mp4 which are two parts of same file. To run videos you now have to download both separetely, this can be done by keeping close eye on IDM-popups for mp4 and mpa, then compile both using some mixer to create one file which supports the algorithm of youtube to demix them, and then you have a .flv file which can be played.
.flv = .mp4 + .mpa
2) do you have any solution for this? -
Abhishek Rawal
Like I said,It's not "Youtube provides".micheal johnyou are right, when i IDM-popup it is showing MPA and MP4 format files not flv. But 1) what is the reason for youtube to separete audio and video files into two separete format? and
It is what "IDM" provides.
Go to #-Link-Snipped-# & copy the url of the video you wanna download.
And plenty download options will pop.
Or you can even use extension/addon in Firefox like what #-Link-Snipped-# mentioned. -
Abhijit DeyGuys Google have changed a lot of their buffering techniques! The videos from YouTube are buffered into different files and are linked together while playback. Earlier there was a method better than downloading the videos, which was searching for your videos in the cache folder of Chrome, but now they have changed that too.
Flash Video Downloader is the best as a Firefox extension. With this add-on you can select to download in all the formats, YouTube has stored the video on their server. -
pushkar jainNayan GoenkaCalm down everyone, the issue is not what you all think so, Since past two months, youtube has started to store the video and audio parts of any file separately. So when you download anything from youtube, instead of the .flv now you get .mpa and .mp4 which are two parts of same file. To run videos you now have to download both separetely, this can be done by keeping close eye on IDM-popups for mp4 and mpa, then compile both using some mixer to create one file which supports the algorithm of youtube to demix them, and then you have a .flv file which can be played.
.flv = .mp4 + .mpa
which mixing software we have to use???and in google chrome browser i am not getting the options for dowloading videos...by clicking(in chrome) on idm it asks me to download some different files(i think links) which are just around 10kb memory wat to do for this.... -
pushkar jainAbhishek RawalLOL.
dude could u xplain some elaborately how to download videos by using the method u suggested....thanx in advance -
pushkar jainone more way is install "video download helper" add on in firefox then u can get the link for downloading the required video which should be pasted in idm and get ur videos and njoy.....
rahul69micheal johnI use internet download manager to download youtube videos and other sites video....thanks for you reply......pushkar jaindude could u xplain some elaborately how to download videos by using the method u suggested....thanx in advance
Check out this link, maybe it can help:
#-Link-Snipped-# -
VVikash
You Just use IDM Latest version (idm 6.19) and Patch it, otherwise if you want to download youtube videos, then add some add-on in mozilla Like 1-click youtube (Link: #-Link-Snipped-# ) easy youtube video downloader and many more add on available for firefox browser, and also add Download them all (DownThemAll! â Get this Extension for ð¦ Firefox (en-US)) and Enjoy.....micheal johnI use internet download manager to download youtube videos and other sites video. i have been using IDM for past 2 years, but from past 2 month i have a problem - i am able to download videos, after download completed and i open the video using vlc player but video doesn't play. can anyone help me to resolve this issue? thanks for you reply...... -
Raghu vara teja
Can u suggest patch for IDM in Windows 8.1VVikashYou Just use IDM Latest version (idm 6.19) and Patch it, otherwise if you want to download youtube videos, then add some add-on in mozilla Like 1-click youtube (Link: #-Link-Snipped-# ) easy youtube video downloader and many more add on available for firefox browser, and also add Download them all (DownThemAll! â Get this Extension for ð¦ Firefox (en-US)) and Enjoy..... -
Raghu vara tejaCan u suggest patch for IDM in Windows 8.1
Shane RandalI think the problem lies with the encoding.
Just follow these steps.
go to Program Files >> Google >> Chrome >> Application
>>(recent version of chrome, which would be something like 38.0.2125.111)
here, look for a file named "ffmpegsumo.dll". Just rename this file.
Restart Chrome, open youtube and try downloading again.
[Update]: Renaming ffmpegsumo.dll doesn't work anymore. But try downloading the plugin #-Link-Snipped-# which disables the youtube HTML5 player. You will be able to download youtube videos through IDM as you used to. -
Jatin KumarThe problem is that officially youtube don't want you to download videos from it, because that further lead to piracy .So Downloading videos is not simple now as before we used to do it.And this problem is also existing if you use keepvid,
So follow these steps
1)if you want to download any video ,go to Address bar ,and type "SS" after the link eg. #-Link-Snipped-# . this will direct you to website savefromnt
where you have option of downloading it from in differnt format ,and also with Idm. -
Jatin Kumar
Search for idm hosts file method ,it works for all version of idm and windows.Raghu vara tejaCan u suggest patch for IDM in Windows 8.1 -
ABHI SAVALIYASOLVED BY ME!!
GUYS ..
FOLLOW THESE STEPS
JUST OPEN NEW TAB IN GOOGLE CHROME
DRAG DOWNLOADED FILE IN NEW TAB!!!
VIDEO WORKS FINE!!!!!!!!!!
I HAVE SHOWN HOW TO PROCEED (IN PICS)!!!!!! -
batpool52!Very common issue. You'll need to download videos via clipconverter.cc
Shane RandalIssue Finally Solved.
Cause :
The problem is all because of HTML5 player. Due to forced webM VP8 format, IDM was unable to download separate files and combine them to generate a proper video.
Solution :
Download a plugin that disables HTML5 player.
Previously, just renaming a file called "ffmpegsumo.dll" would disable the HTML5 player, but since the latest chrome update, renaming this file would crash the video player. So it won't solve the problem anymore. -
waquar alam
Dont be panic dear..micheal johnI use internet download manager to download youtube videos and other sites video. i have been using IDM for past 2 years, but from past 2 month i have a problem - i am able to download videos, after download completed and i open the video using vlc player but video doesn't play. can anyone help me to resolve this issue? thanks for you reply......
m giving u solution..
download pot player and update its codes..
run that video using this..
it will play like charm..
cheers -
waquar alamDont be panic dear..
cheers -
RyanspazIts the HTML5 player use disable HTML5 palyer extension in the chrome extension and walla its done not IDM problem
Sharfudeen Mohamed IbrahimIf you really want to download the youtube videos, try to download by IDM by usin this website ► savefrom.net this might work 😀
Abhishek Rawal
I know Microsoft is making a big deal of the XBOX ONE; but trust me, you gotta see this -
I hope you're excited about the future 😉
Just saw a website webprofitsdirect.in and they claim to have brought work from home easier in India. Has anyone actually used this and earned cash for real? Just curious.😒
Yahoo's shopping spree hasn't ended yet since it started acquiring startups from quite some time as Marissa Mayer the CEO, believes that these companies are aligned to Yahoo's business. After...
Swimming is something which I have always loved, and whenever I find time to spare, I would straight away head to the pool. For me it's a workout which is...
I am too lazy to surf today, anyone willing to find me a direct download link for Hackintosh 10.8 OS, No torrents please 😁 someone find me a good download...
