Brainy Puzzles
Puzzle Solvers: Interesting brainy puzzles shared by fellow puzzlers
405 Members
Rashmi Gandhi
Rashmi Gandhi • Jul 3, 2019
There Are 8 Batteries And Only 4 of Them Work - Google Puzzle
You have a GPS that takes 2 working batteries. You have 8 batteries but only 4 of them work.
What is the fewest number of pairs you need to test to guarantee you can get the GPS on?
Rashmi Gandhi
Guys do post explanations with your answers
It is a bit involved explanation, which I shall post later.
In my opinion, in the worst case it will need 8 Trials to guarantee success.
Minimum 1 trial and maximum 4 trails are required
Rashmi Gandhi
Rashmi Gandhi • Jul 8, 2019
@Ramani Aswath @sourav tomar You need to post an explanation or steps of how you came to that answer.
Also, any more takers for this?
Assumption: The individuals cells cannot be checked. The only way is to put them in the gadget in pairs and check whether the equipment comes on.
Procedure: Label the cells A-B-C-D-E-F-G-H. A good cell is given a value 1 and a dud one 0.
Divde the cells into pairs, A-B, C-D, E-F, and G-H to start with. The value of the four pairs has to be one of the following:
1. (A-B):(C-D):(E-F):(G-H) = (0,0):(0,0):(1-1):(1-1)
2. (A-B):(C-D):(E-F):(G-H) = (0:0):(1-0 OR 0-1):((1-0 OR 0-1):(1,1) and lastly
3. (A-B):(C-D):(E-F):(G-H) = (1-0 OR 0-1):(1-0 OR 0-1):(1-0 OR 0-1):(1-0 OR 0-1)
We start with loading the cells into the gadget one pair at a time and checking for functioning.
For option 1 above, the worst case will be: The first two can fail but the third pair must work.
For option 2 above, the worst case will be: The first three can fail but the fourth pair must work.
For option 3 above, all four pairs will fail. Take any two pairs, say A-B and C-D. These can form maximum four combinations:
(A-C):(A-D):(B-C):(B-D) having values (0-0): (1-0 OR 0-1): (1-0 OR 0-1):(1-1)
Try these pairs one at a time.
The worst case will be: The first three can fail but the fourth pair must work.
So without any prior knowledge of the status of each cell, we need a minimum of 8 trials to guarantee success.
If one is lucky, the very first pair can work, but no guarantee!
Prudvi Raj
Prudvi Raj • Jul 9, 2019
Total pairs that can be formed=8c2=28 pairs
There are three cases possible...
1.both not working= 4c2=6
2.1 working and 1 not working=4c1.4c1=16
3.both working=4c2=6
So finally ,min trails=1
Max trails=16+6+1=23
I am wrong. 8 is not the answer.
