Technology difference between FPR 3D TV & SG 3D TV:
FPR (Film-Type Patterned retarder) 3D;
The best part of LGโs FPR 3D TV is their lightweight & affordable 3D glasses and 2D to 3D conversation. The 3D conversation option allow 3D TV user to enjoy their usual programs in 3D without having the actual 3D content.
SG (Shutter Glass) 3D;
So these are some major advantage of FPR 3D TV & some disadvantages of SG 3D TV....!
- Lightweight 3D glasses without power batteries, comfortable to use for long time.
- No image flickering occur since, no dizziness or no eye fatigue.
- Bright 3D images with wide viewing angle.
- High refresh-rate up to 240 Hz/sec.
- Image without overlapping, hence no crosstalk happen.
- 2D to 3D content conversation.
- Electric batteries attached there on SG glasses, due to which SG glasses were heavy & uncomfortable as compare to FPR 3D glasses.
- Image flicker arise as one glass was always closed in SG 3d glasses.
- Dark 3D images because of traditional 3d tech.
- Low refresh-rate only 60 Hz/sec.
- Image overlapping generally occurs due to the SG glasses
- No 2D to 3D conversation there in SG 3D TV.
JanasheenNice differentiation.......but does, referesh rate really affect on the 3D tv performance....?
naman12d2d to 3d conversation is just a crap it cant be possible at any cost.
nikhilnabhoj
I think yes...!JanasheenNice differentiation.......but does, referesh rate really affect on the 3D tv performance....? -
namishnandi
I don't think so, since performance of 3D TV is totally based on its technology not on its refresh-rate.JanasheenNice differentiation.......but does, referesh rate really affect on the 3D tv performance....? -
Akram Shah
Before April 26 it was just a crap really! But since, LG launched its FPR 3D TV in India so, that crap is not a crap anymore, LG promised to their consumers that with advanced 2D to 3D conversation feature in FPR 3D TV, you don't need to worry about availability of 3D content as it automatically convert your normal 2D content into 3D.naman12d2d to 3d conversation is just a crap it cant be possible at any cost. -
myselfkhan
Yes, refresh-rate affect a lot on 3D TV performance, because if a TV is not performing at a fast speed, so the viewers will start irritating as 3D in slow is not acceptable at any cost. Although 3D TV is too expensive & after spending a huge amount on 3d tv, person still not getting fast response speed then its of no use.JanasheenNice differentiation.......but does, referesh rate really affect on the 3D tv performance....?
So in order to enjoy the better 3D affect, person should choose the tv which provides the high refresh-rate.
Faiz Bilgiramy
Well, buddy refresh-rate is again the part of technology as Khan mention in its thread that in SG refresh-rate is only 60 Hz/sec, but FPR has a High refresh-rate up to 240 Hz/sec.namishnandiI don't think so, since performance of 3D TV is totally based on its technology not on its refresh-rate.
So i believe that referesh rate vary with tech differences.
Although, you right that tech plays a big role in performance of 3d tv, but again refersh-rate is the part of tech, so it's also matters a lot....! -
namishnandiDoes SG manufacturer still uses the power batteries in their SG 3D glasses....?
nikhilnabhoj
Yes, they can't changenamishnandiDoes SG manufacturer still uses the power batteries in their SG 3D glasses....? -
namishnandiI am perplexed whether FPR 3D glasses is well-suited with SG 3d TV or not.๐..?
awesome!I don't think so, because LG's FPR 3D technology is totally different from SG 3D tech.
But if someone knows about it then share it here plz...๐! -
namishnandiThat's means SG user can't experience FPR 3d glasses with their SG 3D TV๐...untill they change their TV set.
awesome!
My best answer is yes...since it's a matter of tech change.namishnandiThat's means SG user can't experience FPR 3d glasses with their SG 3D TV๐...untill they change their TV set. -
myselfkhan
Yeah they can't experience fpr 3d glasses in sg 3d tv..namishnandiThat's means SG user can't experience FPR 3d glasses with their SG 3D TV๐...untill they change their TV set.
the fact behind is, in SG a film is attached on 3d glasses only,
whereas in fpr a film is attached to 3d glasses or on screen also..!!!
So because of this difference fpr glasses is not compatible with sg 3d tv. -
asheoranpink< links snipped by admin>
namishnandiSo friends, does anyone knows that SG 3D TV manufacturers are planning to adopt FPR tech or not ???
awesome!
Hey!asheoranpink< links snipped by admin>
What does it means? -
Harshad Italiya
It meas that guy has posted some advertisement link which is not allowed so admin removed that links. ๐awesome!Hey!
awesome!
Ok!godfatherIt meas that guy has posted some advertisement link which is not allowed so admin removed that links. ๐
Thanks a ton. -
blue.blackIs FPR technology really a matter of concern for those using SG Technology?
Akram Shah
Yep! Definitely as (Film-Type Patterned Retarder) FPR is a tech which has very light weight & affordable 3d glasses,blue.blackIs FPR technology really a matter of concern for those using SG Technology?
produces flicker-free images, 2d-3d conversation etc.
where as in (Shutter Glass) SG tech, we have a 3d glasses which consists a power battery that makes them heavy as compare to the fpr 3d glass/
Although SG 3d tech has its own working principal but different with FPR. -
blue.black
Thanks Akram..Akram ShahYep! Definitely as (Film-Type Patterned Retarder) FPR is a tech which has very light weight & affordable 3d glasses,
I have one more query running in my mind...although you just told me that 3D Glasses in FPR is affordable but is this whole system of FPR is less costlier than SG 3D Tech? -
blue.black
Hmmm...Okey !choprak77Yes, i think it is, as it's already discussed above that the two technologies are totally different.
So the advanced features of FPR 3D technology will be missed by the SG 3d tv users.
Thanks a lot. -
Akram Shah
No not at all 3d glasses are affordable as to compare to SG because power battery is not there in FPR 3d glasses.blue.blackThanks Akram..
but whole FPR 3d tv set is expensive as compare to SG 3D TVs because of technology difference.
As FPR 3d tech is vast than SG, its technically sound more than SG. That's why FPR 3D TV's expensive than SG 3D TVs..... -
blue.black
Okey..Akram ShahNo not at all 3d glasses are affordable as to compare to SG because power battery is not there in FPR 3d glasses.
That means FPR Tech is costlier and expensive than the SG 3D TVs.. -
obey_almighty
Yeah..!blue.blackOkey..
FPR tech is more costlier than the SG 3D TV but it's not that importnat because FPR is having true good features than SG. -
Anshul KumarNodoubt FPR tech is better than SG tech because of its commendable features and easy to use applications.. ๐
bob_jonnyi think such a high refresh rate ( 240 Hz ) is required for games only, for movies 60/120 Hz is sufficient isn't it? what do u think guys?
gaurav kaus
So are SG 3DTV technology's manufacturer's are doing anything to enhance their technology??nikhilnabhojYes, they can't change -
vishan karjee
Ya i do to agree on the fact that refresh rate affect the performance.myselfkhanYes, refresh-rate affect a lot on 3D TV performance, because if a TV is not performing at a fast speed, so the viewers will start irritating as 3D in slow is not acceptable at any cost. Although 3D TV is too expensive & after spending a huge amount on 3d tv, person still not getting fast response speed then its of no use.
We cannot sit whole day to watch one action to happen.
Action rate is therefore another important as well as advantages of FPR 3DTV -
abhishekjainajk
Yes they do. But now they are planning on shifting to fpr soonnamishnandiDoes SG manufacturer still uses the power batteries in their SG 3D glasses....? -
Akram Shah
You are right but, 240 Hz is also required for action movies, animation movies etc....bob_jonnyi think such a high refresh rate ( 240 Hz ) is required for games only, for movies 60/120 Hz is sufficient isn't it? what do u think guys?
as referesh rate provide us fast response speed which help us to watch our programe without any delay or without image overlapping.
so high referesh rate matters a lot in tv performance....!!! -
blue.black
I agree with you Vishan Karjee...because when we sit to watch a movie or play a game, we have a specified period of time to spend on it..vishan karjeeYa i do to agree on the fact that refresh rate affect the performance.
Not just this..Slow performance makes the interest of the viewer go dull...
And Hi-Refresh Rate also gives more clarity to the view...
Thus Hi-Refresh Rate is important.. -
ankurr89
I am not sure that SG technology's manufacturer's are doing anythin to enhance their technology,gaurav kausSo are SG 3DTV technology's manufacturer's are doing anything to enhance their technology??
But FPR have become so popular and favorite among the manufacturer's and user's as well.
FPR also has superior qualities and services which has got great response.
I want electrical engineering mini project ideas. The idea should be easy to understand and execute.
Hello Ceans we came back with an Awesome interview with one of our CE โ Maniac. She is CEan - freak16, a 3rd year Crazy Electrical Engineer joined us around...
๐๐๐๐๐๐๐
Hi,
I have confusion of representation of relationships in database schema suppose A ir private owner who owns B property for rent are tables as shown below
Table- PrivateOwner...
Hello friends,
Why don't we post some funny mobile messages that we receive every day?
We all can enjoy by reading them
What say people?
Hello friends, I always wanted to write something about this on forum.
The topic chosen by me this time is Engine valve timing diagram.
Now what is it exactly? Let...
