Swirling problem at boiler’s start-up
At boiler’s start-up, one should take care of water swirling at boiler’s Drum, especially when you start at [FONT="]Cold Start Mode.[/FONT]
Swirling at cold start, makes water level fluctuates very much at the [FONT="]Drum[/FONT]. Therefore it can trip the boiler with [FONT="]Drum level Hi Hi protection[/FONT] ([FONT="]MFT).[/FONT]
Imagine you have some of water in a kettle, and you start boiling the water, the mixture will be water and bubbles. That is what happened at drum but with so many fluctuations.
Water swirling takes time until [FONT="]water level[/FONT] stabilize, when a build up pressure at Drum equal to [FONT="]1 barg[/FONT]. You can notice this from the [FONT="]Drum level indicator[/FONT].
So, how can we eliminate such this problem?
1- Open [FONT="]start up blow off[/FONT] valves ( 2 valves )
2- Open [FONT="]continuous blow down[/FONT] valve ( 1 valve )
3- Reduce [FONT="]warm up fuel[/FONT] flow mass ( rate of fuel )
https://science-hamza.blogspot.com/
gohmIn addition to the mechaincals aspects, there are also chemical treatments that can assist, specially anti-foaming agents.
khaled hamzaCan you tell us more about chemical aspects in such this phenomena ?
Reverse Power Protection., Theory & Setting .
1- Protection against overspend 32G (# 1).
In case of Turbine Failure, the Turbine is tripped and then the...
Earthing System is very important issue for electrical distribution , so I attached files talking about types of earthing , I hope it benefits you all.
EARTHING_SYSTEMS_PPT
Get Your...
Interesting videos!
Learning to push your limits!
[video=youtube;1fecfhcIFSM]https://www.youtube.com/watch?v=1fecfhcIFSM&feature=player_embedded[/video]
[video=youtube;QGJ6j9m9XeU]https://www.youtube.com/watch?v=QGJ6j9m9XeU&feature=player_embedded[/video]
[video=youtube;7yomQ3bh1ZY]https://www.youtube.com/watch?v=7yomQ3bh1ZY&feature=player_embedded[/video]
[video=youtube;JqzFpZm8oEg]https://www.youtube.com/watch?v=JqzFpZm8oEg&feature=player_embedded[/video]
[video=youtube;U6Ku80nVnP8]https://www.youtube.com/watch?v=U6Ku80nVnP8&feature=player_embedded[/video]
[video=youtube;mjfGLc7-V-0]https://www.youtube.com/watch?v=mjfGLc7-V-0&feature=player_embedded[/video]
[video=youtube;LX3BTbwLJ8k]https://www.youtube.com/watch?v=LX3BTbwLJ8k&feature=player_embedded[/video]
[video=youtube;PEww8yt2PeQ]https://www.youtube.com/watch?v=PEww8yt2PeQ&feature=player_embedded[/video]
[video=youtube;z_W54F0QT0Y]https://www.youtube.com/watch?v=z_W54F0QT0Y&feature=player_embedded[/video]
[video=youtube;eOjVZRKo6Gg]https://www.youtube.com/watch?v=eOjVZRKo6Gg&feature=player_embedded[/video]
[video=youtube;wFGhV3uwv1A]https://www.youtube.com/watch?v=wFGhV3uwv1A&feature=player_embedded[/video]
[video=youtube;Cb4H2oqPkSI]https://www.youtube.com/watch?v=Cb4H2oqPkSI&feature=player_embedded[/video]
[video=youtube;lOVSBT29kP8]https://www.youtube.com/watch?v=lOVSBT29kP8&feature=player_embedded[/video]
[video=youtube;PV4WIJZeujc]https://www.youtube.com/watch?v=PV4WIJZeujc&feature=player_embedded[/video]
[video=youtube;d3sbEljEnIc]https://www.youtube.com/watch?v=d3sbEljEnIc&feature=player_embedded[/video]
Vacuum low reasons:
1. Check condenser surface area, make sure it is clean (you can do inspection for one room while the other still in service and you need to...
Self-Flushing Debris Filter
The quality of the cooling water intake and the amount of debris in that water affects the operation and performance of the condenser and therefore the thermal...
