Refresh your BTech/BE CS/IT books -1
Hello everyone,
The idea for this thread is to refresh your old things/concepts studied in BTech/BE . May be of help to those who are working in MNCs but forgetting things day by day after doing rubbish work as well to those who are preparing for jobs specially in IT industry.
Rules:
Topic: SQL
Qn: GROUP BY, ORDER BY can be used in WHERE clause ?
a) True
b) False.
[Again: Avoid spamming and post count to reach more than 30.]
Thanks !
Rules:
- Read each and every rule clearly.
- No kind of spamming and rules breaking will be tolerated here. ๐
- Everyone is free to answer the same question again even if it is correctly answered by soemone else.
- Try to give options while asking questions so as it makes easy for newbies(Can call First Year students) to make guess.
- If possible give possible explanation with each question or any other related information so as people can learn more things from just 1 question.
- Mention the topic of subject before posting the question.
- Wait for me to start next thread as soon as this thread reaches count of 30. Don't post anything once count reaches 30.
- While answering please copy the question also so as to make the things look clearly.
Topic: SQL
a) True
b) False.
Thanks !
shalini_goel14Topic: SQL
a) True
b) False.
Ans: False.
As WHERE clause is used to specify the conditions on the basis of which query should be executed and for GROUP BY , HAVING clause is used to specify the conditions.
[PS: Feel free to correct me if wrong].
Topic: Datawarehousing
Qn: What are the categories of OLAP tools(Online Analytical Processing) ? -
shalini_goel14*bump *
Hey where are CS/IT CEans ? No one knows the answer of my question. Is it so difficult? ๐ -
debu
Hey guys! I'm not a BE/BTech CS/IT, I hope you don't mind my answering your question.shalini_goel14Topic: Datawarehousing
There are:
- Multidimensional (MOLAP)
- Relational (ROLAP)
- Hybrid (HOLAP)
- Web Based (WOLAP)
- Desktop (DOLAP)
- Real-Time(RTOLAP)
Regards,
Debu ๐ -
shalini_goel14
Not at all. You are absolutely right. Even I read only first three in my BTech but you told me 3 more. ๐debuHey guys! I'm not a BE/BTech CS/IT, I hope you don't mind my answering your question.
There are:
- Hybrid (HOLAP)
- Web Based (WOLAP)
- Desktop (DOLAP)
- Real-Time(RTOLAP)
Thanks ! -
manusalujaOK, one question from my side on DataBase...
Why is a UNION ALL faster than a UNION?
very easy one guys... . -
shalini_goel14
UNION ALL is faster than UNION because UNION ALL simply fetches all the records(including duplicate rows) from two queries into single result set while in case of UNION first all records(including duplicate rows) are fetched into a single result set and then duplicate ones are eliminated. UNION creates temporary table with index just to eliminate duplicate rows.manusalujaOK, one question from my side on DataBase...
Right?
FYI,
UNION and UNION ALL is an operator in SQL statements which is used to combine results of two SELECT statements.
UNION: It is used to select distinct values from two tables.
UNION ALL: It is used to select all records(even duplicate) from two tables.
Can check this also for more information: SQL UNION Operator -
manusaluja
ya, perfectly right.shalini_goel14UNION ALL is faster than UNION because UNION ALL simply fetches all the records(including duplicate rows) from two queries into single result set while in case of UNION first all records(including duplicate rows) are fetched into a single result set and then duplicate ones are eliminated. UNION creates temporary table with index just to eliminate duplicate rows.
Right?
FYI,
next question from computer networks....
2. Which of the following is done in the physical layer of the ATM network?
(a) Cell multiplexing and demultiplexing
(b) Generic flow control
(c) Transmission frame generation/ recovery
(d) Monitoring of the user information field for bit errors and possible corrective actions
P.S. - I was thinking to ask question from toughest subject automata, anyways, next question will be from there,. Be Prepared
shalini_goel14Qn : Which of the following is done in the physical layer of the ATM network?
Ans is a) Cell Multiplexing and demultiplexing ? ATM network Physical layer is similar to OSI (Open System Interconnection ) Reference Model ?
A very heartily Hi to every vibrating engineering life here.....
I'm from Surat, India.
I have acquired B.E Electrical Engg. 4 year ago.
And right now involved in the work...
Please i need a help with this report, please
REPORT:
Consider a frequency-flat fading channel. Use two methods, namely Jakes's
model and the filtered Gaussian noise model to simulate a...
Hi
Iam doing my first year Electronics & Communication engineering in bangalore, would like to do short term course during my holidays.
Can anyone suggest what courses will be helpful....
OK s ,
What this thread is supposed to do ? You all are supposed to post an image related to your current location or place nearest to your location...
CEans,
I just got the news that about 7500 employees from Satyam have been asked to stop coming to the office from 19[sup]th[/sup]June. New terms & conditions will be put...
