Real time Problems/Challenges
Hi everyone,
Feel proud in calling yourself as a computer/IT engineer ๐ ? Simple, in this thread - a sort of challenge will be thrown for all such engineers. The challenge will be based on live situations that software engineers face in their everyday life and solutions of such problems is not mentioned or taught directly in any engineering books. But if you use your little bit of brains and concepts taught in engineering or in any training, they can be solved. So any one calling him/her as a CS/IT engineer would like to solve simple problems I am going to throw in this thread ?
Problem : You have following two tables and you are supposed to write a simplest SQL query that would give me data as shown in Table 3
Table 1 : REF_ASSET_LIABILITY with structure as following:
ASSET_LIABILITY_ID - Primary key -NUMBER(10,0)
ASEET_LIABILITY_NAME - VARCHAR2(20)
Table 2 : PORTFOLIO_HOLDING with structure as following:
PORTFOLIO_ID - NUMBER(10,0)
PORTFOLIO_NAME - VARCHAR2(20)
CUSTOMER_ID - VARCHAR2(10) -FOREIGN KEY[SOME OTHER TABLE]
BUY_COST -NUMBER(23,5)
MARKET_VALUE -NUMBER(23,5)
ASSET_LIABILITY_ID - NUMBER(10,0) -FOREIGN KEY[REF_ASSET_LIABILITY]
Now I just need to get the data from these tables in the following form
Table 3: Outcome
PS: Everyone is free to throw REAL TIME challenges/problems in this thread.
Note: Not direct questions should be included that can be EASILY find in any books. ๐
[EDIT]
Also in above problem a check should be made where CUSTOMER_ID=C1. Though it is not necessary but it would be better if you people include it also in the query.
Table 3: Outcome
[EDIT]
safwanHi , sooki
I just want one question for above given question.
fro column allocated % assets wise the data is necessary to shown as given in colum . -
sookie
Good question, I was expecting it. Thanks for at least giving it a try. ๐safwanHi , sooki
No, the column should show only the values, I have shown them only for calculation purposes. I assumed people would remove that part by default. So in last column , you need to show only the calculated values only as e.g 47.37, 52.63, 46.87, 53.13. Approximation is allowed but only upto 2 decimal places.
*Thinking is it really so tough to solve or are people here so DUMB to solve ๐ * -
Ashraf HZIf you give them a bar of Cadbury chocolate, perhaps they will be interested to solve ๐
vik001indThere is problem in your question -- customer_id should be varchar rather than number as it holds the value "C1"
my answer (assuming customer_id is of type varchar)
select portfolio_name,aseet_liability_name,market_value as 'allocated_value',round(((allocated_value/(100+allocated_value))*100),2) as 'allocated %-asset wise' from ref_asset_liability,portfolio_holding where customer_id = "C1" AND ref_asset_liabilty.aseet_liability_name = portfolio_holding.asset_liability_id
I haven't executed it, so i'm not sure whether its right or wrong! -
Manish Goyal
helloo vi001ind your query IS Perfect but i think there should be small modificationvik001indThere is problem in your question -- customer_id should be varchar rather than number as it holds the value "C1"
ie it should be like this
select portfolio_name,aseet_liability_name,market_value as 'allocated_value',round(((market_value/(100+market_value))*100),2) as 'allocated %-asset wise' from ref_asset_liability,portfolio_holding where customer_id = "C1" AND ref_asset_liabilty.aseet_liability_name = portfolio_holding.asset_liability_id;
i think it should run hope so in MySql -
vik001indThat was a silly mistake. damn it!
hit me, someone plz !! ! -
sookieHey guys, well done ๐
@vik Thanks for correcting out my problem. Actually I was supposed to write C1 as 1 and C2 as 2 in the PORTFOLIO_HOLDING table but for better understanding of problem , I marked it as C1 , C2 because reference table for CUSTOMER details is not shown in the problem in order to avoid complications in the problem. Anyway, I am editing my mistake. :sshhh:
Now coming to the problem in actual -
You people are dividing the market value by (100 +market value) but in actual the problem is like that market_value should be divided by (sum of total market values in same portfolio)
Hint: Grouping should be done based on "Portfolios" -
vik001indselect portfolio_name,aseet_liability_name,market_value as "allocated_value",round(((market_value/(sum(market_value)))*100),2) as "allocated %-asset wise" from ref_asset_liability,portfolio_holding where customer_id = 'C1' AND ref_asset_liabilty.aseet_liability_name = portfolio_holding.aseet_liability_id group by portfolio_name
sookie
Good attempt but dude it will give syntax error as group by function is not used correctly.vik001indselect portfolio_name,aseet_liability_name,market_value as "allocated_value",round(((market_value/(sum(market_value)))*100),2) as "allocated %-asset wise" from ref_asset_liability,portfolio_holding where customer_id = 'C1' AND ref_asset_liabilty.aseet_liability_name = portfolio_holding.aseet_liability_id group by portfolio_name
PS: Really liking your spirit of trying. Keep it up. ๐ -
Gurjeet SinghsookieGood attempt but dude it will give syntax error as group by function is not used correctly.
dude can u plz check the datatype of the both tables as the data in the first table is numeric and u enter 1,2,3 so on and now in the second table u are shwing the values in the asset_liablity id which is A1,A2...so on which is var char..so first of all data type mismatch in foregin key as compare to primary key....... -
vik001ind
Its correct!cooldudeietdude can u plz check the datatype of the both tables as the data in the first table is numeric and u enter 1,2,3 so on and now in the second table u are shwing the values in the asset_liablity id which is A1,A2...so on which is var char..so first of all data type mismatch in foregin key as compare to primary key.......
checkout the condition, i'm giving in my sql query. -
sookie
Thanks for pointing out, "My Big Apologies" for that. Looks like I posted wrong image url. ๐cooldudeietdude can u plz check the datatype of the both tables as the data in the first table is numeric and u enter 1,2,3 so on and now in the second table u are shwing the values in the asset_liablity id which is A1,A2...so on which is var char..so first of all data type mismatch in foregin key as compare to primary key.......
Hope now everything is fine. -
vik001indselect portfolio_name,aseet_liability_name,market_value as 'allocated_value',round(((market_value/(sum(market_value)))*100),2) as 'allocated %-asset wise' from ref_asset_liability,portfolio_holding where customer_id = "C1" AND ref_asset_liabilty.aseet_liability_id = portfolio_holding.aseet_liability_id group by portfolio_name,portfolio_id
I have screwed my head for many hours over this question, suggest some hint, if this is wrong. -
safwanSQL< select portfolio_name,asset_liability_name,market_value as "allocated_value",market_value/sum(market_value)*100 as "aloocateed % -assetwise" from ref_asset_liability_name,portfolio_holding where customer_id='C1' and ref_asset_liability.asset_liability_name=portfolio_holding.asset_liability_id group by asset_liability_name
well this was my try but oops I saw I think my answer is wrong ๐but never mind . I will try next answer. ๐ -
sookieCorrecting you people's mistake only a bit [rest of the brainy part still left] -
In group by add following fields
portfolio_name, asset_liability_name, market_value .
So query will look like this
select portfolio_name,aseet_liability_name,market_value as 'allocated_value',round(((market_value/(sum(market_value)))*100),2) as 'allocated %-asset wise' from ref_asset_liability,portfolio_holding where customer_id = "C1" AND ref_asset_liabilty.aseet_liability_id = portfolio_holding.aseet_liability_id group by portfolio_name, asset_liability_name, market_value
In group by function you need to add all those columns that are being fetched using select . Now if you are taking market_value also in group by then grouping will be done based on market_value also . So % allocation part will always return "1" as a value. So you need to brainstorm at that part .
Hint: Use group by but at correct place. If you can do so, its ok otherwise wait for the solution. -
sookieHi everyone,
Thanks a lot for the attempts you all have shown for the problem here. Wait is over now - here is the solution for those who are interested to know [AS PER ME] .
My Apologies, for making the bugs full problem :sshhh: . In table 2 PORTFOLIO_HOLDING, as per the data PORTFOLIO_ID cannot be Primary Key. So I have added a separate column "ID" in that table and made it as primary key.
So revised table structures along with data are as follows:
Table 1: REF_ASSET_LIABILITY
Table 2: PORTFOLIO_HOLDING
Now we need the output something like below
So if we write simple query as
"SELECT PORTFOLIO_HOLDING.PORTFOLIO_NAME, REF_ASSET_LIABILITY.ASSET_LIABILITY_NAME,
Output will give only first 3 columns of actual output. So, we need to think for Column no 4.
PORTFOLIO_HOLDING.MARKET_VALUE AS "ALLOCATED_VALUE"
FROM PORTFOLIO_HOLDING PORTFOLIO_HOLDING,REF_ASSET_LIABILITY REF_ASSET_LIABILITY
WHERE PORTFOLIO_HOLDING.ASSET_LIABILITY_ID = REF_ASSET_LIABILITY.ASSET_LIABILITY_ID"
Now if I write simple query like following
"SELECT INNER_PORTFOLIO_HOLDING.PORTFOLIO_ID, SUM(INNER_PORTFOLIO_HOLDING.MARKET_VALUE)
I will get output like following - showing the total sum by which I need to divide column3 [Of Actual Output table] .
FROM PORTFOLIO_HOLDING INNER_PORTFOLIO_HOLDING,REF_ASSET_LIABILITY REF_ASSET_LIABILITY
WHERE INNER_PORTFOLIO_HOLDING.ASSET_LIABILITY_ID = REF_ASSET_LIABILITY.ASSET_LIABILITY_ID
GROUP BY INNER_PORTFOLIO_HOLDING.PORTFOLIO_ID
Now, if I divide Column3 by above query by just adding one simple condition more, I will get the desired output. So final query will be
Everyone is free to correct me if any better optimized query is possible for this problem. ๐
PORTFOLIO_HOLDING.MARKET_VALUE AS "ALLOCATED_VALUE",
ROUND(PORTFOLIO_HOLDING.MARKET_VALUE*100/
(SELECT SUM(INNER_PORTFOLIO_HOLDING.MARKET_VALUE)
AND INNER_PORTFOLIO_HOLDING.PORTFOLIO_ID =PORTFOLIO_HOLDING.PORTFOLIO_ID
),2) AS "ALLOCATED%-ASSET_WISE"
This one is out of my own, personal curiosity. What's involved in building a simple web search engine?
Let's say, we have a network of 1000 (or 10?) terminals each...
Occam Networks New High-Density Gigabit Ethernet FTTP Blade Featuring Highest Port Density in Its Class on Display at ITU Telecom World in Geneva
48 Ports Per Blade Combines with Integrated...
A short article about DARPA funded experiments to remotely control insects - in this case beetles:
Free-flying cyborg insects steered from a distance - tech - 01 October 2009 -...
here is a problem which i face when i participate in a online programming competition
can any any one solve it
Problem Statement:
Now comes an interesting math game.
How...
Hi friends , can some of you please list some project topics based on Cryptography ; not too tough but on the easier side ? I am a final year...
