Qtp 10.0
This is the thread where we can discuss the new features of QTP 10.0:
NEW FEATURES
· Manage Testing Assets, Dependencies, and Versions in Quality Center (QC) 10.0 - QTP 10.0 has enhanced integration with Quality Center that provides support for asset versioning and asset comparison
·Perform Local System Monitoring While Running Your Tests - This feature (found at File > Settings > Local System Monitor) enables you to monitor the local computer resources used by the application you are testing during a run session. This will enable you to more greatly determine the affect your test is having on the system at run-time.
·Add Portability by Saving Copies of Tests with Their Resource Files - If you need to execute tests that utilizes resources stored in Quality Center, in an environment that doesn't have access to the network or Quality Center, this feature will be extremely useful. It provides the ability to save a standalone, local copy of the tests with its associated resources.
·Develop Your own Bitmap Checkpoint Comparison Algorithm - With this feature, you can develop custom comparer COM objects that perform bitmap checkpoints according to your test requirements.
·Manage Your Testing Tasks in the To Do Pane - This new To-Do pane enables you to create and manage self-defined tasks, and to view a compiled set of the To-Do comments from your tests, components, and associated function library.
·Improve Test Results Analysis with New Reporting Functionality - New functionality includes Jump to Step, exporting results to Word or PDF formats, adding images to ReportEvent steps, difference images for bitmap checkpoints, and additional information for Quality Center runs.
·Call Actions Dynamically During the Test Run - With the new LoadAndRunAction statement, you now have the ability to load and run an action only when the step with the statement is executed.This is useful, for example, if you use many conditional statements that call external actions, and you do not want to load all of these actions each time you open the test, since these actions may not be necessary during the run session.
·Test Standard and Custom Delphi Objects - With the new Delphi Add-in, you can test Win32 VCL Delphi control.
PRODUCT ENHANCEMENTS
· Upgrade from QuickTest 9.5 - If you have QTP 9.5 Installed on the system, you can choose to upgrade to version 10.0. This will allow you to preserve some of the configuration settings and options that you already have set up.
·Improved IntelliSense Functionality - QTP now provides full IntelliSense for objects created by a step or function (i.e. objects created by CreateObject method), variables to which an object is assigned, reserved objects, COM objects and properties that return objects. In addition, Intellisense sentence completion now provides lists of local variables.
·Added Control for Editing and Managing Actions in Automation Scripts - The QTP Automation Object Model has a new set of objects and methods for manipulating test actions and action parameters. You can use automation scripts to create new actions, modify and validate the syntax of action scripts, create and modify action parameters, and more.
·Improved Debugger Pane Design and Functionality - The Debug Viewer pan has a new look, including icons to help you identify the type of information displayed.
·New Object Identification Solutions in Maintenance Run Mode - In addition to helping you update your steps and object repositories when objects in application change, the Maintenance Run Wizard can now help you solve problems dealing with test failures due to missing objects, or objects that can only be recognized via Smart Identification.
·Additional Configuration Settings for Text Recognition Mechanism - You can now set all text recognition configuration settings from the QuickTest Options Dialog Box.
·New Look for Options, Settings, and File Dialog Boxes - The QuickTest Options and Settings dialog boxes have changed from their former ta-based design to a more easily navigable tree-based structure. The tree contains only the options relevant for the add-ins that are currently loaded.
·QuickTest Toolbar Customization Options - You can use the new Customize Dialog box to customize the appearance of existing menus and toolbars, and to create your own user-defined menus, toolbar buttons, and shortcuts.
·Improved Web Extensibility - QTP Web Add-in Extensibility enables you to develop packages that provide high level support for thir-party and custom Web controls that are not supported out-of-the-box by the Web Add-in.
·.NET Add-in and Extensibility Improvements - The .NET Add-in has several new objects and methods, including the SwfPropertyGrid test object (for working with .NET Windows Forms property grids), GetErrorProviderText method and ErrorProviderText identification property.
·New Terminal Emulator Configuration Validation - The new Terminal Emulator pane of the Options dialog box now includes a Validate button. When you click this button, QTP checks the current configurations of the selected emulator. If a problem is detected, a brief description is displayed in the pane.
NEW SUPPORTED OPERATING SYSTEMS AND ENVIRONMENTS
· Microsoft Windows 2008 Server 32-bit Edition
·Microsoft Windows 2008 Server 64-bit Edition
·Microsoft Windows Vista, Service Pack 1, 32-bit Edition
·Microsoft Windows Vista, Service Pack 1, 64-bit Edition
·Microsoft Windows XP Professional 32-bit Edition -- Service Pack 3
·Citrix Presentation Server 4.5
·Microsoft Internet Explorer 8, Beta 2
·Mozilla firefox 3.0.x
·Delphi: IDE, versions 6, 7, and 2007 (for controls based on the Win32 VCL library)
·SAP: CRM 2007 (For controls that support test mode enhancements
·Java: IBM 32-bit JDK 1.5.x, SWT toolkit version 3.4
·Java Extensibility: Eclipse IDE 3.4
·.NET: .NET Framework 3.5 -- Service Pack 1
Feel free to post your experience/queries with QTP 10.0
    Mention the source, Sire 😀
  • Anil Jain
    Anil Jain
    Sorry Biggi.. forgot the refrence site:
  • Saandeep Sreerambatla
    Great Info Anil,
    The Jump to step and Identification will be pretty much useful i guess.
  • Anil Jain
    Anil Jain
    Improved reporting and tight coupling with QC are also great sign of improvement.
    -Crazy
  • safwan
    safwan
    Can any one explain what is QTP 10.0 ?
  • saurabh
    saurabh
    QTP stands for Quick Test Professional..
    its a software used for testing......
    Testing is one of the steps in s/w development life cycle....
    Nice info Crazyboy...thank u very much i was looking for it....
    Same way can u please give me the information for enhancement of Oracle8i to Oracle9i....
Thin Computing is a technology which delivers the productivity, people need at a lower cost than traditional methods, all without compromising security or manageability. Thin Computing replaces the PC with...
Hi CEans, my project is "wireless electronics notice board". The project is built around the AT89C51 micro controller from Atmel. This micro controller provides all the functionality of the display...
what is the reason of negative resistance in UJT . plz explain in some detail
Palisade demonstrates the use of DecisionTools Suite in financial risk quantification for environmental remediation and site cleanup efforts Invitation to free webcast – Friday 2 April 2009 John Lynch, president...
According to web analytics firm StatCounter, Firefox 3 has ousted Internet Explorer 7 as the most used web browser use in Europe. Good news, but it's not exactly as rosy...
