Programming in C/C++ under Linux
I'll use this opportunity and ask about programming in C/C++ under Linux.
I've just popped in Fedora 10 in my PC, and I'm wondering how can I make C/C++ applications and executables under Linux. Also, I want to ask if the .NET platform can be used under Linux.
Kaustubh KatdarePost moved to a new thread in Computer Science & IT Engineering section.
MaRoCode::blocks with gcc is good choice for programming on Ubuntu & Fedora.
You can't install .NET platform but there is clones for .NET languages like C# & its clone Mono. -
durga chyou can use KDevelop or QT or Eclipse plug ins for C as IDE
Corpse-ThrustOkay, thanks for the info mates.
Is this .NET clone similar to the original .NET's GUI? Or is it different?
The gcc thingy, I guess this is the compiler right? Do I have to download it or is it provided with the Fedora Linux?
Sorry, complete Linux n00b here... -
MaRoGet started with mono #-Link-Snipped-#
Not sure if it's installed by default but Installing GCC- GNU Project is very useful. -
Kaustubh KatdareMaRoGet started with mono #-Link-Snipped-#
Thanks for the links, MaRo. Mono project looks interesting. -
pradeep_agrawalFor programming C/C++ under linux i feel the tools gcc, gpp, gdb, make will be useful. FInd below the links for same.
gcc/gpp: Compile C/C++ code
Link: GCC, the GNU Compiler Collection- GNU Project
gdb: Debugging the executable
Link: GDB Documentation
make: For handling compilation of multiple files in project
-Pradeep -
sheekobest compiler:gnu
best IDE: netbeans
Well here are some snaps I took today at the race. Was excited to also ride along in the ffr cobra!
05/23/09 cdc ax bowie - a set on Flickr
Hi CE😛
In this thread we talk about reuse of bik or its componant. Evey year so many bike are going in trush or it will take a corner of...
Hi All,
Have you ever tried of spending few minutes on thinking about your DREAM as an engineer ?
If don't want to think and have no time - Go...
hey..
can we add up the mass moment of inertia's of different bodies rotating about the same axis to get the total mass moment of inertia of the entire system....?
sir,
I am studying 4th year B.Tech.i want the mini project i.e., 8 bit alu design with vhdl code.
so,you are kindly requested to post this project .please kindly help...
